Pirate Audio plug-in fails to install SocketIO-client
Volumio Information
Volumio Version: 2.9.07
Hardware: RPi Zero
DAC: Pirate Audio Headphone - Hifiberry DAC
I have tried installing the Pirate Audio Plugin through the Volumio interface and manually from github with the same results.
Downloading socketIO-client-0.7.2.tar.gz
Running setup.py (path:/tmp/pip-build-fp_2PD/socketIO-client/setup.py) egg_info for package socketIO-client
warning: no files found matching '*.html'
warning: no files found matching '*.js'
warning: no previously-included files matching '*.pyc' found anywhere in distribution
Downloading/unpacking requests>=2.7.0 (from socketIO-client)
Cleaning up...
Exception:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1266, in prepare_files
req_to_install.extras):
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2401, in requires
dm = self._dep_map
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2597, in _dep_map
self.__dep_map = self._compute_dependencies()
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2621, in _compute_dependencies
parsed = next(parse_requirements(distvers))
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 49, in
next = lambda o: o.next()
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2721, in parse_requirements
"version spec")
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2686, in scan_list
raise ValueError(msg, line, "at", line[p:])
ValueError: ('Expected version spec in', 'charset-normalizer ~=2.0.0', 'at', ' ~=2.0.0')
Any ideas?
Greetings!
Iā€™d recommend you try looking at the last few posts over at [Plugin] pirate audio - #57 by AxLED for some ideas.
My bet would be that this is a similar issue as in Cannot install build-essential package - #13 by Adrii because of a hybrid Stretch/Jessie base Volumio currently uses.
