Pine64 touchscreen
Hi all,
has anyone been using Volumio on the Pine64 with the according Touchscreen LCD? I am running Volumio on a few RPIs with touchscreen which worked pretty smoothly with the according plugin. The Pine64 seems not to work out of the box, so before digging deeper I thought it makes sense to ask if anyone has solved this yet. The display with case and battery is super slick and would make up for a very neat portable multimedia device around the house.
All the best
daniel
