Je possede un pine 64 2GB avec volumio installé dans une carte sd de 16GB. Mon probleme est que j’ai un son affreux avec les fichiers flac.
Je peux les lires mais il y a des gresillements. J’ai essayé avec plusieurs albums en flac meme souci.
Mais pour le mp3 ou le webradio ca fonctionne très bien.
Quelqu un pourrait il m’aider (si une personne comprends le francais desolé)
My French is not very good, but you are saying that you have a Pine 64, running Volumio (which version?), with sound problems with flac files (crackling??)? Are you using an external DAC, and if so, which one?
Ok, you have a pine 64 and awfull sound with flac files. Basically it works, but not without issues and this counts for several albums.
But with mp3 or webradio pine works very well.
I presume you are using the 3.5mm jack, you would have those issues because of the onboard DAC.
The only real solution is to use a good external DAC (usb Audio).
That said, there is a way to improve it for some files, but you will not get it to play absolutely everything.
You would have to edit /ect/mpd.conf
Change the line with “44100:16:2” to “44100:24:2” (without the quotes), I could play most of my flac that way.
It’s not perfect as mpd then resamples, let me know how it goes.
What model is your marantz and what sort of DAC does it have.
Perhaps we can experiment with mpd.conf setting.
It would also be good to know what bitrate your flac files have.
