After the latest update (v2.799} is dual mono/stereo not available in the playback options , I’ll had to set it in alsamixer.
Same… Though everything is still working and the Piano 2.1 is connected via the 1st and 4th RCA sockets still.
We are checking, thanks for reporting.
This new version uses a new kernel which changed quite a lot of things on the ALSA side…
Unfortunately I cannot find my PIano 2.1 …
Do you mind to post the output of
aplay -l ?
and
alsamixer
when you select the Piano 2.1 using f6?
thanks!
here you go!
volumio@volumio-kali-piano:~$ aplay -l
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
card 2: PianoDACPlus [PianoDACPlus], device 0: PianoDACPlus multicodec-0 [PianoDACPlus multicodec-0]
Subdevices: 0/1
Sorry but still don’t understand why it does not work…
Need to find again mine…
I had had this strange thing in earlier versions, but somehow it disappeared and the dual mono option just came back after a while.
a friend of mine has had this problem in the past and also went away after a while.
besides, I also have an allo isolator and kali reclocker in between.
I have the same problem.
volumio@valemusica:~$ aplay -l
Subdevices: 4/4
Subdevices: 4/4
Subdevices: 1/1
i can confirm this on a fresh install v2.799 with my rpi3b+ & piano2.1 & kali
Advanced DSP options for allo piano 2.1 are gone.
