Hi, since Volumio 2.834 the left channel of my Piano 2.1 installation is not working anymore with Spotify. After Factory Reset, left channel works with web radio but as soon as I use the Spotify plugin it breaks again. Any help welcomed. Thank you.
PS where can i find previsous volumio downloads ? thanks
well. not really. I’ve downloaded and installed the previous version 2.699 which has the options for the Allo Piano 2.1 DAC. But there’s still a problem with the volume on the left channel when using the DAC in Dual-Mono mode (haven’t tried other modes) with the Spotify Connect 1.05 plugin.
I’m not sure what is happening but the volume on the left channel fades over time. I have to go back to the web interface and turn the volume up again. Btw. It only works for the left channel. So, I turn it up to 100% and all is fine. Then over time it sinks back to 5% by itself (MPD volume control for clients is deactivated). Thats kind of spooky.
Did something change recently? It used to work fine previously.
The daemon doesn’t do anything fancy, it just requires the correct mixer-name, card and index. If it gets the right values, it should work
I don’t have the DAC, but can you check if the Volumio API gives us the correct parameters?
You could check by examining the configuration file for vollibrespot
Then you could open alsamixer and check which of the mixers move when you change the volume from Volumio webUI for web radio, and which one changes when you use Spotify connect.
The problem is that this DAC has 2 separate mixers (one for left and one for right), so Volspotconnect is actually setting the volume of the left channel only and ignoring the right one.
I had a bit of a head scratching moment – I thought I had implemented things wrong, but as far I can tell, it’s correct. This in turn hooks into ALSA’s snd_mixer_selem_set_playback_dB_all which
Set value in dB of playback volume control for all channels of a mixer simple element.
But if the driver use two separate mixers for each channel, then it should also probably provide a Master mixer that maps to both these channels as stereo.
You can then of course set them independently for that perfect balance
amixer sset Master 40%,42%
Anyone from allo on here? Thoughts?
Okay, peeking at the driver’s source indicates that things should work as expected with the new driver?
hi, sorry to bump this but there is a problem with this DAC and the Spotify plugin. Allo.com ? could you please chime in?
The left channel just fades away over time, even when the player is left on . The remedy is to push the volume to 100% manually via the volumio web interface.
i own also a couple of Piano 2.1 hats and hope someone could fix the issues with that DAC, that is sounding very well in Dual Mono Mode - especially in conjunction with an Allo Kali.
