I just bought and setup a new PI4B/2G (Rev. 1.5) with the latest Volumio Version v3.198. Problem: my Qudelix 5k USB Dongle/Headphone Amp produces a lot of noise. Sometimes it works flawless at the beginning of a song, but the noise gets more and more when running for a longer time.
Problems exist with USB3 as well as USB2 ports of the PI4
The Qudelix (96kHz/24Bit Dac) works flawless with my older PI2 (Volumio v3.179) and connected to PC
I connected an old Terratec AureonDualUSB Soundcard/Headphone Donge (also 96kHz/24Bit edit: only 48/16 as I found out) to the PI4 - also works without any problem, so it seems it is nothing wrong with the USB ports of the PI4
Connecting via SSH and starting htop shows no excessive load when using the Qudelix
Happens with Qobuz streaming as well as with FLAC files from my NAS (didn´t test other file types yet).
Still not sure if it a Qudelix, PI4-USB or Volumio Problem.
Just did a testinstall of piCorePlayer to see if it´s a Volumio problem or not. Unfortunately (for me of course, good news for Volumio) I discovered the same noise there. So looks like I have a pi with faulty or at least bad USB ports (problem exists for both, USB3 and USB2 ports).
Interestingly the USB works with an other external soundcard (Terratec) without any problems. Also the Qudelix works perfect conneted to my PI2, PI3 and PC and laptop.
Is it possible that it is related to the Revision 1.5 kernel?
If I don´t get USB fixed I will probably switch PIs and use the PI4 with an IQAudio HAT in another room. Have to find a fitting case first, looks like they are not available. So I need to spend money and time again.
An other option would be to return it to the seller, but it´s hard to find other new PIs at the moment as most of you know.
Maybe you can try to load the official raspbian image, with one of the embedded players. And see if the USB noise is still there. If it is, then the pi is most likely to blame.
maybe I try over the weekend…as I don´t have a micro-hdmi cable to attach a monitor it will probably involve some more time than installing a dedicated multimedia os from an image…but I try to find the time…
not that more difficult, you can even do it headless. If needed I can PM you a topic that I created for a different player/server to install raspbian headless. you can then use VNC viewer for the desktop.
OK, did a test on the latest Raspberry PI OS (I guess what was called raspbian before). @Wheaten gave me a link, but that was too much effort…I just installed the OS, did update, full-upgrad and rpi-update (also rpi-eeprom-update, but that was already actual), but a 192/24 flac file on the sd, set Alsa to use the Qudelix and played the file using a command line player (moc)…same problem with noise…so no good news here…
gonna try Volumio 3.209 on the PI3 now (or tomorrow)
