tcrisis
December 29, 2016, 1:22am
1
Hi there,
I have tried the solutions of several other threads on here but none have solved the issue I am having. Please redirect me if a solution has already been posted! I am operating a RPi3 with a HiFiBerry DAC + on Volumio 2. I just installed the Spotify plug-in. The installation was successful and the plug-in is active. I entered my premium account credentials (correctly, verified in spopd.conf) and saved. Spotify will show up on browse tab, but my playlists won’t load. I click on My Playlists and nothing happens. Also, when I try to play a song from the featured playlists, they’ll go to my queue but never play.
Playback for Volumio’s web radio stations work just fine, if that helps. Ironically, Spotify worked when I was running Volumio 1.55, but since updating it doesn’t work.
Any help is appreciated! Thanks
EDIT Here is a segment that I think is problematic:
sudo /usr/bin/spopd -c /etc/spopd.conf
/usr/bin/spopd: error while loading shared libraries: libsportify.so.12: cannot open shared object file: No such file or directory
tcrisis:
Hi there,
Can you post your /var/log/volumio.log file so we can take a look at it. Thanks!
tcrisis
December 29, 2016, 2:36am
3
2016-12-28T23:58:54.112Z - info: -------------------------------------------
2016-12-28T23:58:54.118Z - info: ----- Volumio2 ----
2016-12-28T23:58:54.119Z - info: -------------------------------------------
2016-12-28T23:58:54.119Z - info: ----- System startup ----
2016-12-28T23:58:54.120Z - info: -------------------------------------------
2016-12-28T23:58:54.372Z - info: Plugin folders cleanup
2016-12-28T23:58:54.373Z - info: Scanning into folder /volumio/app/plugins/
2016-12-28T23:58:54.373Z - info: Scanning category audio_interface
2016-12-28T23:58:54.375Z - info: Scanning category miscellanea
2016-12-28T23:58:54.377Z - info: Scanning category music_service
2016-12-28T23:58:54.378Z - info: Scanning category plugins.json
2016-12-28T23:58:54.379Z - info: Scanning category system_controller
2016-12-28T23:58:54.381Z - info: Scanning category user_interface
2016-12-28T23:58:54.382Z - info: Scanning into folder /data/plugins/
2016-12-28T23:58:54.382Z - info: Scanning category music_service
2016-12-28T23:58:54.383Z - info: Plugin folders cleanup completed
2016-12-28T23:58:54.385Z - info: Loading plugins from folder /volumio/app/plugins/
2016-12-28T23:58:54.392Z - info: Loading plugins from folder /data/plugins/
2016-12-28T23:58:54.395Z - info: Loading plugin "system"...
2016-12-28T23:58:54.447Z - info: Loading plugin "appearance"...
2016-12-28T23:58:55.076Z - info: Loading plugin "network"...
2016-12-28T23:58:55.236Z - info: Loading plugin "services"...
2016-12-28T23:58:55.247Z - info: Loading plugin "alsa_controller"...
2016-12-28T23:58:55.489Z - info: Loading plugin "volumio_command_line_client"...
2016-12-28T23:58:55.507Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:58:55.509Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:58:55.510Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:58:55.567Z - info: Loading plugin "upnp"...
2016-12-28T23:58:55.578Z - info: [1482969535577] Starting Upmpd Daemon
2016-12-28T23:58:55.608Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2016-12-28T23:58:55.611Z - info: Loading plugin "mpd"...
2016-12-28T23:58:55.742Z - info: Loading plugin "networkfs"...
2016-12-28T23:58:55.786Z - info: Loading plugin "alarm-clock"...
2016-12-28T23:58:56.054Z - info: Loading plugin "airplay_emulation"...
2016-12-28T23:58:56.069Z - info: [1482969536068] Starting Shairport Sync
2016-12-28T23:58:56.076Z - info: Loading plugin "last_100"...
2016-12-28T23:58:56.087Z - info: Loading plugin "webradio"...
2016-12-28T23:58:57.955Z - info: Loading plugin "i2s_dacs"...
2016-12-28T23:58:57.976Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2016-12-28T23:58:57.978Z - info: Loading plugin "my_volumio"...
2016-12-28T23:58:57.984Z - info: Loading plugin "volumiodiscovery"...
2016-12-28T23:58:58.083Z - info: Applying required configuration parameters for plugin volumiodiscovery
2016-12-28T23:58:58.134Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2016-12-28T23:58:58.138Z - info: Loading plugin "albumart"...
2016-12-28T23:58:58.162Z - info: Plugin example_plugin is not enabled
2016-12-28T23:58:58.165Z - info: Loading plugin "updater_comm"...
2016-12-28T23:58:58.498Z - info: Plugin mpdemulation is not enabled
2016-12-28T23:58:58.501Z - info: Loading plugin "rest_api"...
2016-12-28T23:58:58.526Z - info: Loading plugin "websocket"...
2016-12-28T23:58:58.601Z - info: Loading plugin "spop"...
2016-12-28T23:59:00.744Z - info: Applying required configuration parameters for plugin spop
2016-12-28T23:59:00.768Z - info: ___________ START PLUGINS ___________
2016-12-28T23:59:00.787Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2016-12-28T23:59:00.792Z - info: [1482969540789] CoreMusicLibrary::Adding element Last_100
2016-12-28T23:59:00.820Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2016-12-28T23:59:00.823Z - info: [1482969540820] CoreMusicLibrary::Adding element Webradio
2016-12-28T23:59:00.867Z - info: Loading i18n strings for locale en
2016-12-28T23:59:00.986Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:59:00.989Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getAlsaCards
2016-12-28T23:59:01.009Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:59:01.017Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:59:01.021Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:59:01.025Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:59:01.030Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2016-12-28T23:59:01.073Z - info: BOOT COMPLETED
2016-12-28T23:59:01.217Z - info: [1482969541213] CoreStateMachine::resetVolumioState
2016-12-28T23:59:01.224Z - info: [1482969541219] CoreStateMachine::getcurrentVolume
2016-12-28T23:59:01.227Z - info: CoreCommandRouter::volumioRetrievevolume
2016-12-28T23:59:01.284Z - info: [1482969541267] CoreStateMachine::updateTrackBlock
2016-12-28T23:59:01.296Z - info: [1482969541286] CorePlayQueue::getTrackBlock
2016-12-28T23:59:01.540Z - info: SpopD Daemon Started
2016-12-28T23:59:01.550Z - info: MPD running with PID571 ,establishing connection
2016-12-28T23:59:01.586Z - info: Setting Device type: Raspberry PI
2016-12-28T23:59:01.917Z - info: [1482969541915] VolumeController:: Volume=56 Mute =false
2016-12-28T23:59:01.924Z - info: [1482969541923] CoreStateMachine::pushState
2016-12-28T23:59:01.928Z - info: [1482969541926] CoreStateMachine::getState
2016-12-28T23:59:01.930Z - info: [1482969541929] CorePlayQueue::getTrack 0
2016-12-28T23:59:01.933Z - info: CoreCommandRouter::volumioPushState
2016-12-28T23:59:01.934Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2016-12-28T23:59:01.945Z - info: [1482969541943] interfaceApi::pushState
2016-12-28T23:59:01.947Z - info: [1482969541946] InterfaceWebUI::pushState
2016-12-28T23:59:02.008Z - info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
2016-12-28T23:59:02.212Z - info: Reloading queue from file
2016-12-28T23:59:02.338Z - info:
2016-12-28T23:59:02.378Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2016-12-28T23:59:02.488Z - info: mDNS: Found device Volumio
2016-12-28T23:59:02.608Z - info: Upmpdcli Daemon Started
2016-12-28T23:59:02.656Z - info: [1482969542655] Shairport-Sync Started
2016-12-28T23:59:04.090Z - info: CoreCommandRouter::volumioGetState
2016-12-28T23:59:04.092Z - info: [1482969544091] CoreStateMachine::getState
2016-12-28T23:59:04.095Z - info: [1482969544093] CorePlayQueue::getTrack 0
2016-12-28T23:59:04.105Z - info:
[1482969544098] ---------------------------- Client requests Volumio state
2016-12-28T23:59:04.111Z - info: [1482969544110] InterfaceWebUI::pushState
2016-12-28T23:59:04.146Z - info: [1482969544144] ------------------------------ 56ms
2016-12-28T23:59:06.545Z - info: Connecting to daemon
2016-12-28T23:59:06.648Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2016-12-28T23:59:06.650Z - info: [1482969546649] CoreMusicLibrary::Adding element Spotify
2016-12-28T23:59:06.657Z - info: FIRST BRANCH
2016-12-29T02:20:39.273Z - info: mDNS: A device disapperared from network
2016-12-29T02:20:39.277Z - info: mDNS: Device volumio disapperared from network
2016-12-29T02:20:39.484Z - info: mDNS: Found device Volumio
2016-12-29T02:20:42.367Z - info: Volumio called home
2016-12-29T02:20:46.178Z - info: Spotify access token expires at 1482973146550
2016-12-29T02:20:46.179Z - info: Spotify access token is BQDY9I86ZY1022xqydMMmfbLfjdMTjaLPYDsaaMtSGBqTp1z-y8mOHqbDlkaAOwMbFHDDrzw9w9x8zkFQyI53Q
2016-12-29T02:20:46.180Z - info: Spotify credentials grant success
2016-12-29T02:22:29.387Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2016-12-29T02:22:29.398Z - info: CoreCommandRouter::volumioGetState
2016-12-29T02:22:29.399Z - info: [1482978149399] CoreStateMachine::getState
2016-12-29T02:22:29.400Z - info: [1482978149400] CorePlayQueue::getTrack 0
2016-12-29T02:22:29.401Z - info:
[1482978149400] ---------------------------- Client requests Volumio state
2016-12-29T02:22:29.403Z - info: [1482978149403] Listing playlists
2016-12-29T02:22:29.421Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2016-12-29T02:22:29.423Z - info:
[1482978149422] ---------------------------- Client requests Menu Items
2016-12-29T02:22:29.424Z - info: CoreCommandRouter::volumioGetBrowseSources
2016-12-29T02:22:29.426Z - info: CoreCommandRouter::volumioGetQueue
2016-12-29T02:22:29.427Z - info: [1482978149427] CoreStateMachine::getQueue
2016-12-29T02:22:29.429Z - info: [1482978149428] CorePlayQueue::getQueue
[1482978149429] ---------------------------- Client requests Volumio queue
2016-12-29T02:22:29.431Z - info: [1482978149430] InterfaceWebUI::pushState
2016-12-29T02:22:29.463Z - info: [1482978149462] InterfaceWebUI::pushQueue
2016-12-29T02:22:29.466Z - info: [1482978149465] ------------------------------ 67ms
2016-12-29T02:22:29.468Z - info: [1482978149467] ------------------------------ 42ms
2016-12-29T02:22:29.527Z - info: [1482978149526] ------------------------------ 104ms
2016-12-29T02:24:29.375Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2016-12-29T02:26:19.494Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2016-12-29T02:28:39.925Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2016-12-29T02:31:09.960Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2016-12-29T02:31:09.978Z - info: CoreCommandRouter::volumioGetState
2016-12-29T02:31:09.980Z - info: [1482978669978] CoreStateMachine::getState
2016-12-29T02:31:09.982Z - info: [1482978669980] CorePlayQueue::getTrack 0
2016-12-29T02:31:09.985Z - info:
[1482978669982] ---------------------------- Client requests Volumio state
2016-12-29T02:31:09.991Z - info: [1482978669987] Listing playlists
2016-12-29T02:31:10.025Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2016-12-29T02:31:10.031Z - info:
[1482978670029] ---------------------------- Client requests Menu Items
2016-12-29T02:31:10.033Z - info: CoreCommandRouter::volumioGetBrowseSources
2016-12-29T02:31:10.035Z - info: CoreCommandRouter::volumioGetQueue
2016-12-29T02:31:10.036Z - info: [1482978670035] CoreStateMachine::getQueue
2016-12-29T02:31:10.037Z - info: [1482978670036] CorePlayQueue::getQueue
2016-12-29T02:31:10.038Z - info:
[1482978670037] ---------------------------- Client requests Volumio queue
2016-12-29T02:31:10.040Z - info: [1482978670039] InterfaceWebUI::pushState
2016-12-29T02:31:10.075Z - info: [1482978670074] InterfaceWebUI::pushQueue
2016-12-29T02:31:10.079Z - info: [1482978670079] ------------------------------ 103ms
2016-12-29T02:31:10.081Z - info: [1482978670080] ------------------------------ 46ms
2016-12-29T02:31:10.113Z - info: [1482978670112] ------------------------------ 83ms
2016-12-29T02:33:59.929Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
There was a similar issue on this thread:
github.com/volumio/Volumio2/issues/657
Try this - change your Spotify password, log in to Spotify on a PC/Mac to the Spotify Web Player - not the app. Then plug in the new password to the Spotify plugin on Volumio. It’s a long shot, but it might work.
