Hello, it seems I’m not able to use Rasp 5 instead the Rasp 4 with the Pi2aes hat.
Any help?
Thank you
what did you select in the I2S DAC list?
please also make sure you’re running the latest version, a fix for some I2S HATs not working on Pi5 has been fixed
I’ve tried several DAC from the list: ALLO, hifiberry, audiophonics but nothing the stream is not going out to the DAC in fact the hat is not receiving power because there are no leds ON
maybe it’s better to contact the manufacturer for asking if this HAT is compatible with Pi5
Which version of Pi2AES and which power supply are you using?
