Pi Touchscreen problem
Pi3B with official 7 " touchscreen.
Display is up side down
Screen shows blank & Volumio login:
Setup like tutorial > raspberry-pi-display-and-volumio-touchscreen-music-player
Hi audiorudi,
did you install the plugin first time or did you update from a previous version (if so which one)?
Do you see any error messages when you enable the plugin? If so, please post what the error messages tell.
I did the plugin installation for the first time and there where no error messages.
problem is solved
