Hi all.
I have read the common issues page and not found anything before posting this.
I have a 2Gb Pi 4 with Ian Canada power filter, driven by iFi iPower X, connected to both a USB pen drive and a 6Tb external powered USB drive running v3.631 of Volumio. It connects to my home network over Wifi but I just use that for control, not for streaming anything except occasionally Radio Paradise. It’s connected to a Gustard U18/X26pro DAC combo over USB. My files are large 32bit/768kHz files resampled using PGGB. This works fine.
I decided to upgrade to an 8Gb Pi 5 to see if this was snappier and if the extra memory benefitted playback sound quality given the size of the PGGB resampled files. What happens is playback works, but unreliably. For some random reason, playback will pause periodically for 5-10 seconds, and then resume.
I have switched back to the filtered 2Gb Pi 4 using the same micro-SD card I had in the Pi 5 and it is working just fine.
I logged in to the Pi 5 dev URL and ran a log capture which recorded the following whilst in its mystery pause phase:
Lots of these:
error: MyVolumio MQTT error: Error: Not supported
error: MyVolumio MQTT error: Error: Cannot parse topic
error: MyVolumio MQTT error: Error: Connection refused: undefined
and then some of these:
and finally this:
sd 0:0:0:0: [sda] tag#6 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD
sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x88 88 00 00 00 00 01 35 15 72 e0 00 00 01 00 00 00
sd 0:0:0:0: [sda] tag#5 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x88 88 00 00 00 00 01 35 15 71 e0 00 00 01 00 00 00
scsi host0: uas_eh_device_reset_handler start
usb 4-1.1: reset SuperSpeed USB device number 3 using xhci-hcd
scsi host0: uas_eh_device_reset_handler success
Any ideas please? I’d like to use the Pi 5 if possible
