What’s the login information for a fresh install to RPI 4? I’ve tried volumio and volumio and nothing.
Have reflashed the SDcard multiple times and tried 2 different cards.
used credentials are ok, you did enable ssh in ip-address/dev?
Running on a Pi 400 and entering credentials direct via keyboard.
What ended up working was using the Pi Imager and selecting Volumio by name and having it downloaded and flashed.
Using the ZIP file downloaded from the Volumio website would not accept the credentials - using the imager it worked.
So while that solved that issue it really concerns me that these kind of issues exist at the installation phase - does not instill confidence in overal app stability.
