I haven’t seen much info about the Pi3 and Volumio. Is there a reason to buy a Pi2 or a Pi3 for this project?
Thanks!
Thanks!
Of course with PI3 you will have several advantages:
If you don’t care of none of the above, just get a pi2, if not get a pi3 (what I suggest…)
Thank you.
If the software works on the 3, that is what I will buy.
Yes, Volumio works great on Raspberry PI 3.
