Hi everyone.
I wondered if, beyond the digital source selection available in Volumio, someone has already thought at controlling a physical input selector through GPIO pins current levels.
In this thread, you will find a physical source selection board which source is selected electronically by arduino GPIO : Audio Switcher (Arduino) : 5 Steps - Instructables
I would find very elegant to use Volumio to select DAC or RCA (I.e for a turntable or other analog device) input to output to the amplifier in a self contained streamer+amplifier setup. (Volumio is used as input selector in this case, as the sound signal is obviously not passing through the software when another rca than the dac is selected)
It might be feasible by adaptation of a plugin like GPIObutton. Ideally, this input selection should be available from a tile/button on the main screen.
In a nutshell my request aims at having a GPIO pins current combination (group of 3 pins or more) selection available on the main screen to drive extra electronic boards.
If you are aware of such functionality or have an idea to implement it, I would be happy to discuss it.
Benoit
