Phantom Spotify playlist tracks
Prerequisites
Volumio Information
Volumio Version: 2.806
Hardware: RPi4
DAC: M-DAC+ over USB
Debug Log
Steps to Reproduce
  1. See below
Additional Information
I have a fresh install of the Volumio image on the SD card. Installed the Spotify plugin, and gone to a playlist. The first three tracks on the playlist are ‘phantom’ tracks. They are not part of the playlist when viewing it on Spotify (web or app). The playlist was cleared and compiled today (it is a group-edited list). When you click to play any of the three tracks, the fourth track (which is the actual first track on the playlist) starts playing. When you look at other playlists, there are no phantom tracks. If you try to delete any of the phantom tracks, you get the message “Cannot Remove spotify:track:[unique ID]
Factory reset of Volumio, and even reflash of the image on the SD card doesn’t clear the phantom tracks on the playlist.
Is this a Volumio bug, or a Spotify one?
