i cant get the pepptmeter work on my intel nuc on volumio3 buster
here is the error from Xorg.0.log
[ 35.827]
X.Org X Server 1.20.4
[ 35.827] Build Operating System: Linux 4.19.0-12-amd64 x86_64 Debian
[ 35.827] Current Operating System: Linux volumio 5.10.35 #1 SMP Fri Jan 22 21:30:44 CET 2021 x86_64
[ 35.827] Kernel command line: BOOT_IMAGE=/vmlinuz biosdevname=0 splash plymouth.ignore-serial-consoles quiet ro rootwait imgpart=UUID=57e8d8c6-13b2-47f7-9726-80ce12b1407f bootpart=UUID=D83A-828B datapart=UUID=15ab55b1-0e82-413c-aefb-4e10eabae8cf imgfile=/volumio_current.sqsh logo.nologo vt.global_cursor_default=0 acpi_backlight=vendor use_kmsg=yes net.ifnames=0 loglevel=0
[ 35.827] Build Date: 01 December 2020 05:59:57PM
[ 35.827] xorg-server 2:1.20.4-1+deb10u2 (Debian -- User Support)
[ 35.827] Current version of pixman: 0.36.0
[ 35.827] Before reporting problems, check http://wiki.x.org
[ 35.827] Markers: (–) probed, () from config file, (==) default setting,
[ 35.827] (==) Log file: “/home/volumio/.local/share/xorg/Xorg.0.log”, Time: Fri May 28 01:36:58 2021
[ 35.836] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 35.836] (==) No Layout section. Using the first Screen section.
[ 35.836] (==) No screen section available. Using defaults.
[ 35.836] () |–>Screen “Default Screen Section” (0)
[ 35.836] (**) | |–>Monitor “”
[ 35.836] (==) No monitor specified for screen “Default Screen Section”.
[ 35.836] (==) Automatically adding devices
[ 35.836] (==) Automatically enabling devices
[ 35.836] (==) Automatically adding GPU devices
[ 35.843] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 35.843] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 35.843] Entry deleted from font path.
[ 35.847] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 35.847] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 35.847] (II) The server relies on udev to provide the list of input devices.
[ 35.847] (II) Loader magic: 0x55706b214e20
[ 35.847] (II) Module ABI versions:
[ 35.847] X.Org ANSI C Emulation: 0.4
[ 35.847] X.Org Video Driver: 24.0
[ 35.847] X.Org XInput driver : 24.1
[ 35.847] X.Org Server Extension : 10.0
[ 35.847] (EE) systemd-logind: failed to get session: PID 1071 does not belong to any known session
[ 35.848] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 35.860] (–) PCI:*(0@0:2:0) 8086:193b:8086:2064 rev 9, Mem @ 0xdb000000/16777216, 0x90000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x???/131072
[ 35.860] (II) LoadModule: “glx”
[ 35.861] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 35.889] (II) Module glx: vendor=“X.Org Foundation”
[ 35.889] compiled for 1.20.4, module version = 1.0.0
[ 35.889] ABI class: X.Org Server Extension, version 10.0
[ 35.889] (==) Matched modesetting as autoconfigured driver 0
[ 35.889] (==) Matched fbdev as autoconfigured driver 1
[ 35.889] (==) Matched vesa as autoconfigured driver 2
[ 35.889] (==) Assigned the driver to the xf86ConfigLayout
[ 35.889] (II) LoadModule: “modesetting”
[ 35.892] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 35.895] (II) Module modesetting: vendor=“X.Org Foundation”
[ 35.895] compiled for 1.20.4, module version = 1.20.4
[ 35.895] Module class: X.Org Video Driver
[ 35.895] ABI class: X.Org Video Driver, version 24.0
[ 35.895] (II) LoadModule: “fbdev”
[ 35.895] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 35.896] (II) Module fbdev: vendor=“X.Org Foundation”
[ 35.896] compiled for 1.20.0, module version = 0.5.0
[ 35.896] Module class: X.Org Video Driver
[ 35.896] ABI class: X.Org Video Driver, version 24.0
[ 35.896] (II) LoadModule: “vesa”
[ 35.896] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 35.899] (II) Module vesa: vendor=“X.Org Foundation”
[ 35.899] compiled for 1.20.1, module version = 2.4.0
[ 35.899] Module class: X.Org Video Driver
[ 35.899] ABI class: X.Org Video Driver, version 24.0
[ 35.899] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 35.899] (II) FBDEV: driver for framebuffer: fbdev
[ 35.899] (II) VESA: driver for VESA chipsets: vesa
[ 35.899] (EE)
Fatal server error:
[ 35.899] (EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
[ 35.899] (EE)
[ 35.899] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 35.899] (EE) Please also check the log file at “/home/volumio/.local/share/xorg/Xorg.0.log” for additional information.
[ 35.899] (EE)
[ 35.900] (WW) xf86CloseConsole: KDSETMODE failed: Bad file descriptor
[ 35.900] (WW) xf86CloseConsole: VT_GETMODE failed: Bad file descriptor
[ 35.900] (EE) Server terminated with error (1). Closing log file.
Blockquote
