After 2-3 albums the peppy screen savers freezes and Volumio has to be rebooted. What could be the issue and suggestions to resolve
Please post the log, as described here.
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus play
info: Received an update from plugin. extracting info from payload
info: CorePlayQueue::getTrack 11
info: ------------------------------ 30ms
info: ___________ PLUGINS: Run Shutdown Tasks ___________
info: PLUGIN onShutdown : networkfs
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/umount -f /mnt/NAS/MyNasMusic
umount.nfs4: /mnt/NAS/MyNasMusic: device is busy
error: Cannot umount share MyNasMusic : Error: Command failed: /usr/bin/sudo /bin/umount -f /mnt/NAS/MyNasMusic
info: PLUGIN onShutdown : touch_display
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sed -i -e /Option "TransformationMatrix"/d /etc/X11/xorg.conf.d/95-touch_display-plugin.conf
info: touch_display: Touchscreen transformation matrix removed.
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl poweroff
System is powering down.
Condition check resulted in Turns off Raspberry Pi display backlight on shutdown/reboot being skipped.
Unmounting RPC Pipe File System...
info: Shutting Down
Stopped target Bluetooth.
Stopping Volumio Kiosk...
Stopped target Graphical Interface.
Stopping Bluetooth service...
xinit: connection to X server lost
Terminating
systemd-rfkill.socket: Succeeded.
Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopped target Timers.
systemd-tmpfiles-clean.timer: Succeeded.
Stopped Daily Cleanup of Temporary Directories.
Stopped target RPC Port Mapper.
man-db.timer: Succeeded.
Stopped Daily man-db regeneration.
Stopping SDP server
Exit
Starting DeskPi Safeshutdown Service...
Stopping DeskPi PWM Control Fan Service...
apt-daily-upgrade.timer: Succeeded.
Stopped Daily apt upgrade and clean activities.
apt-daily.timer: Succeeded.
Stopped Daily apt download activities.
bluetooth.service: Succeeded.
Stopped Bluetooth service.
deskpi.service: Main process exited, code=killed, status=15/TERM
deskpi.service: Succeeded.
Stopped DeskPi PWM Control Fan Service.
run-rpc_pipefs.mount: Succeeded.
Unmounted RPC Pipe File System.
Stopped target Multi-User System.
Stopping LSB: exim Mail Transport Agent...
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Stopping UPnP Renderer front-end to MPD...
Stopping Music Player Daemon...
Stopped target Login Prompts.
Stopping Getty on tty1...
root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/fanStop
Stopping Samba SMB Daemon...
Stopping volumio-remote-updater.service...
Stopping LSB: set CPUFreq kernel parameters...
Stopping OpenBSD Secure Shell server...
Received signal 15; terminating.
Stopping Volumio Streaming Daemon...
ntpd exiting on signal 15 (Terminated)
Stopping Network Time Service...
212.59.0.2 local addr 192.168.68.115 ->
Stopping Shairport Sync - AirPlay Audio Receiver...
159.65.174.140 local addr 192.168.68.115 ->
Stopping Regular background program processing daemon...
212.51.144.44 local addr 192.168.68.115 ->
Stopping triggerhappy global hotkey daemon...
78.46.102.180 local addr 192.168.68.115 ->
116.12.47.30 local addr 192.168.68.115 ->
85.214.127.75 local addr 192.168.68.115 ->
45.79.13.206 local addr 192.168.68.115 ->
162.248.241.94 local addr 192.168.68.115 ->
131.234.220.232 local addr 192.168.68.115 ->
37.59.63.125 local addr 192.168.68.115 ->
83.212.108.245 local addr 192.168.68.115 ->
31.28.161.71 local addr 192.168.68.115 ->
13.84.173.66 local addr 192.168.68.115 ->
45.63.54.13 local addr 192.168.68.115 ->
5.45.109.152 local addr 192.168.68.115 ->
Stopping LSB: Brings up/down network automatically...
62.112.195.56 local addr 192.168.68.115 ->
194.239.208.213 local addr 192.168.68.115 ->
Stopping Login Service...
bthelper@hci0.service: Succeeded.
Stopped Raspberry Pi bluetooth helper.
Stopping Configure Bluetooth Modems connected by UART...
Removed slice system-bthelper.slice.
triggerhappy.service: Succeeded.
Stopped triggerhappy global hotkey daemon.
systemd-logind.service: Succeeded.
Stopped Login Service.
volumio-remote-updater.service: Main process exited, code=killed, status=15/TERM
volumio-remote-updater.service: Succeeded.
Stopped volumio-remote-updater.service.
cron.service: Main process exited, code=killed, status=15/TERM
cron.service: Succeeded.
Stopped Regular background program processing daemon.
ssh.service: Succeeded.
Stopped OpenBSD Secure Shell server.
getty@tty1.service: Main process exited, code=killed, status=15/TERM
getty@tty1.service: Succeeded.
Stopped Getty on tty1.
ntp.service: Succeeded.
Stopped Network Time Service.
smbd.service: Main process exited, code=killed, status=15/TERM
smbd.service: Succeeded.
Stopped Samba SMB Daemon.
shairport-sync.service: Succeeded.
Stopped Shairport Sync - AirPlay Audio Receiver.
volumio-streaming-daemon.service: Main process exited, code=killed, status=15/TERM
volumio-streaming-daemon.service: Succeeded.
Stopped Volumio Streaming Daemon.
error: Upnp client error: Error: read ECONNRESET
mpd.service: Succeeded.
Stopped Music Player Daemon.
hciuart.service: Succeeded.
Stopped Configure Bluetooth Modems connected by UART.
Stopping MTA:.
exim4.service: Succeeded.
Stopped LSB: exim Mail Transport Agent.
cpufrequtils.service: Succeeded.
Stopped LSB: set CPUFreq kernel parameters.
Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
Stopped target System Time Synchronized.
Stopped target Sound Card.
error: touch_display: Xserver unix domain socket cannot be determined.
Exiting.
Stopping Save/Restore Sound Card State...
[2023/01/08 16:55:10.018412, 0] ../source3/winbindd/winbindd.c:244(winbindd_sig_term_handler)
Stopping Avahi mDNS/DNS-SD Stack...
Got sig[15] terminate (is_parent=1)
Got SIGTERM, quitting.
Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.68.124.
Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.68.115.
Stopping Samba Winbind Daemon...
[2023/01/08 16:55:10.031680, 0] ../source3/winbindd/winbindd.c:244(winbindd_sig_term_handler)
Got sig[15] terminate (is_parent=0)
Starting Show Plymouth Power Off Screen...
Removed slice system-getty.slice.
Stopping Permit User Sessions...
rc-local.service: Succeeded.
Stopped /etc/rc.local Compatibility.
Received SIGRTMIN+20 from PID 2190 (plymouthd).
avahi-daemon 0.7 exiting.
avahi-daemon.service: Succeeded.
Stopped Avahi mDNS/DNS-SD Stack.
winbind.service: Succeeded.
Stopped Samba Winbind Daemon.
info: Discovery: Browse raised the following error Error: dns service error: unknown
error: Discovery: Advertisement error: Error: dns service error: unknown
error: Discovery: advertisement error: Error: dns service error: unknown
alsa-restore.service: Succeeded.
info: Discovery: Advertisement raised the following error Error: dns service error: unknown
Stopped Save/Restore Sound Card State.
Started Show Plymouth Power Off Screen.
systemd-user-sessions.service: Succeeded.
Stopped Permit User Sessions.
Stopping Manage Sound Card State (restore and store)...
[2023/01/08 16:55:10.093137, 0] ../source3/nmbd/nmbd.c:58(terminate)
Got SIGTERM: going down...
Stopping Samba NMB Daemon...
loadcpufreq.service: Succeeded.
Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
nmbd.service: Succeeded.
Stopped Samba NMB Daemon.
alsactl daemon stopped
alsa-state.service: Succeeded.
Stopped Manage Sound Card State (restore and store).
Network Interface Plugging Daemon...stop eth0...done.
ifplugd.service: Succeeded.
Stopped LSB: Brings up/down network automatically.
Stopped target Remote File Systems.
Unmounting /mnt/NAS/MyNasMusic...
mnt-NAS-MyNasMusic.mount: Succeeded.
Unmounted /mnt/NAS/MyNasMusic.
Stopped target Remote File Systems (Pre).
Stopped target NFS client services.
Stopped target Network is Online.
Stopped target Network.
Stopping WPA supplicant...
Stopping ifup for eth0...
Stopping ifup for wlan0...
Stopping Raise network interfaces...
wpa_supplicant.service: Succeeded.
Stopped WPA supplicant.
Stopping D-Bus System Message Bus...
wlan0: pid 2213 deleted IP address 192.168.68.124/24
wlan0: deleting route to 192.168.68.0/24
wlan0: deleting default route via 192.168.68.1
sending commands to master dhcpcd process
dbus.service: Succeeded.
Stopped D-Bus System Message Bus.
wlan0: rebinding lease of 192.168.68.124
control command: /sbin/dhcpcd -k eth0
eth0: removing interface
Starting Live Log...
info: CorePlayQueue::getTrack 10
info: ------------------------------ 63ms
info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
info: CURURI: music-library
info: Preload queue cleared
info: CURURI: music-library/NAS
info: CURURI: music-library/NAS/MyNasMusic
info: CURURI: music-library/NAS/MyNasMusic/Kenny G - Greatest Hits 2CD [The Most Romantic Melodies Of All Time] (2009) 2016
info: CURURI: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps
info: CURURI: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1
info: Preloading song: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-03 Gerry Rafferty - Baker Street.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-08 Don McLean - American Pie.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Don%20McLean/Soft%20Rock%20Ballads/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-08%20Don%20McLean%20-%20American%20Pie.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-08 Don McLean - American Pie.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-10 Chicago - If You Leave Me Now.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Chicago/Soft%20Rock%20Ballads/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-10%20Chicago%20-%20If%20You%20Leave%20Me%20Now.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-10 Chicago - If You Leave Me Now.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-11 Phil Collins - If Leaving Me Is Easy.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Phil%20Collins/Soft%20Rock%20Ballads/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-11%20Phil%20Collins%20-%20If%20Leaving%20Me%20Is%20Easy.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-11 Phil Collins - If Leaving Me Is Easy.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-12 Peter Frampton - Baby I Love Your Way.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Peter%20Frampton/Soft%20Rock%20Ballads/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-12%20Peter%20Frampton%20-%20Baby%20I%20Love%20Your%20Way.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-12 Peter Frampton - Baby I Love Your Way.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-15 Thin Lizzy - Sarah.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Thin%20Lizzy/Soft%20Rock%20Ballads/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-15%20Thin%20Lizzy%20-%20Sarah.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-15 Thin Lizzy - Sarah.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-16 Paul McCartney & Wings - Another Day.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Paul%20McCartney%20%26%20Wings/Soft%20Rock%20Ballads/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-16%20Paul%20McCartney%20%26%20Wings%20-%20Another%20Day.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-16 Paul McCartney & Wings - Another Day.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-18 Al Stewart - Year Of The Cat.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Al%20Stewart/Soft%20Rock%20Ballads/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-18%20Al%20Stewart%20-%20Year%20Of%20The%20Cat.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-18 Al Stewart - Year Of The Cat.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-01 Queen - You're My Best Friend.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Queen/Soft%20Rock%20Ballads%20(Disc%201)/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-01%20Queen%20-%20You're%20My%20Best%20Friend.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-01 Queen - You're My Best Friend.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-04 Steve Miller Band - The Joker.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Steve%20Miller%20Band/Soft%20Rock%20Ballads%20(Disc%201)/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-04%20Steve%20Miller%20Band%20-%20The%20Joker.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-04 Steve Miller Band - The Joker.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-09 David Bowie - Life On Mars_.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=David%20Bowie/Soft%20Rock%20Ballads%20(Disc%201)/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-09%20David%20Bowie%20-%20Life%20On%20Mars_.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-09 David Bowie - Life On Mars_.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-13 Lindisfarne - Lady Eleanor.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Lindisfarne/Soft%20Rock%20Ballads%20(Disc%201)/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-13%20Lindisfarne%20-%20Lady%20Eleanor.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-13 Lindisfarne - Lady Eleanor.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-14 Status Quo - Living On An Island.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=Status%20Quo/Soft%20Rock%20Ballads%20(Disc%201)/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-14%20Status%20Quo%20-%20Living%20On%20An%20Island.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-14 Status Quo - Living On An Island.mp3
info: Exploding uri music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-17 The Beach Boys - Sail On Sailor.mp3 in service mpd
info: ALBUMART /albumart?cacheid=235&web=The%20Beach%20Boys/Soft%20Rock%20Ballads%20(Disc%201)/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSoft%20Rock%20Ballads%203CD%20BoxSet%202013%20320kbps%2FVA%20-%20Soft%20Rock%20Ballads%20Disc%201%2F1-17%20The%20Beach%20Boys%20-%20Sail%20On%20Sailor.mp3&metadata=false
info: URI /mnt/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-17 The Beach Boys - Sail On Sailor.mp3
info: CoreCommandRouter::volumioReplaceandPlayItems
info: CoreStateMachine::ClearQueue
info: CoreStateMachine::stop
info: CoreStateMachine::stPlaybackTimer
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CoreStateMachine::serviceStop
info: CoreCommandRouter::serviceStop
info: ControllerMpd::stop
info: CorePlayQueue::clearPlayQueue
info: CorePlayQueue::saveQueue
info: CoreCommandRouter::volumioPushQueue
info: CoreStateMachine::addQueueItems
info: CorePlayQueue::addQueueItems
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-03 Gerry Rafferty - Baker Street.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-03 Gerry Rafferty - Baker Street.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-05 The Kinks - Days.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-05 The Kinks - Days.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-06 The Doobie Brothers - Listen To The Music.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-06 The Doobie Brothers - Listen To The Music.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-07 Bonnie Tyler - It's A Heartache.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-07 Bonnie Tyler - It's A Heartache.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-08 Don McLean - American Pie.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-08 Don McLean - American Pie.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-10 Chicago - If You Leave Me Now.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-10 Chicago - If You Leave Me Now.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-11 Phil Collins - If Leaving Me Is Easy.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-11 Phil Collins - If Leaving Me Is Easy.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-12 Peter Frampton - Baby I Love Your Way.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-12 Peter Frampton - Baby I Love Your Way.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-15 Thin Lizzy - Sarah.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-15 Thin Lizzy - Sarah.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-16 Paul McCartney & Wings - Another Day.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-16 Paul McCartney & Wings - Another Day.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-18 Al Stewart - Year Of The Cat.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-18 Al Stewart - Year Of The Cat.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-01 Queen - You're My Best Friend.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-01 Queen - You're My Best Friend.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-04 Steve Miller Band - The Joker.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-04 Steve Miller Band - The Joker.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-09 David Bowie - Life On Mars_.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-09 David Bowie - Life On Mars_.mp3
info: Adding Item to queue: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-13 Lindisfarne - Lady Eleanor.mp3
info: Using cached record of: music-library/NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-13 Lindisfarne - Lady Eleanor.mp3
info: CoreCommandRouter::volumioPlay
info: CoreStateMachine::play index 0
info: CoreStateMachine::play index undefined
info: CoreStateMachine::startPlaybackTimer
info: touch_display: Setting screensaver timeout to 60 seconds.
info: sendMpdCommand stop took 230 milliseconds
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info: sendMpdCommand stop took 149 milliseconds
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
info: sendMpdCommand status took 3 milliseconds
info: sendMpdCommand clear took 2 milliseconds
error: updateQueue error: null
info:
info: ------------------------------ 3ms
info: sendMpdCommand playlistinfo took 3 milliseconds
info: sendMpdCommand add "NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-03 Gerry Rafferty - Baker Street.mp3" took 2 milliseconds
error: ControllerMpd::pushError: TypeError: Cannot read property 'split' of undefined
info: ------------------------------ 7ms
info: sendMpdCommand play took 2 milliseconds
info:
info:
info: touch_display: Using Xserver unix domain socket /tmp/.X11-unix/X0
info: sendMpdCommand status took 6 milliseconds
info: sendMpdCommand playlistinfo took 6 milliseconds
info: ControllerMpd::pushState
info: CoreStateMachine::syncState currentStatus stop
info: ------------------------------ 16ms
info: ------------------------------ 50ms
info: CoreCommandRouter::volumioNext
info: CoreStateMachine::next
info:
info: sendMpdCommand stop took 208 milliseconds
info: CorePlayQueue::getTrack 4
info: sendMpdCommand status took 9 milliseconds
info: sendMpdCommand stop took 2 milliseconds
info:
info: sendMpdCommand playlistinfo took 26 milliseconds
info: sendMpdCommand clear took 27 milliseconds
info: CoreStateMachine::syncState stateService stop
info: No code
info: ------------------------------ 124ms
info:
info: ------------------------------ 91ms
info: sendMpdCommand add "NAS/MyNasMusic/Soft Rock Ballads 3CD BoxSet 2013 320kbps/VA - Soft Rock Ballads Disc 1/1-08 Don McLean - American Pie.mp3" took 88 milliseconds
info:
info: ------------------------------ 65ms
info: sendMpdCommand play took 61 milliseconds
info:
info: sendMpdCommand status took 19 milliseconds
info: sendMpdCommand status took 34 milliseconds
info: sendMpdCommand playlistinfo took 34 milliseconds
info: ------------------------------ 61ms
info: sendMpdCommand playlistinfo took 15 milliseconds
info: ------------------------------ 81ms
info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
info: CALLMETHOD: user_interface randomizer randomAlbum undefined
info: CoreCommandRouter::executeOnPlugin: randomizer , randomAlbum
info: CURURI: albums://
info: listAlbums - loading Albums from cache
info: CoreCommandRouter::volumioClearQueue
info: CoreCommandRouter::volumioAddQueueItems
info: Adding Item to queue: albums://Shree 420/Caf%C3%A9 Bollywood - those were the days...%2C Disc 1
info: Exploding uri albums://Shree 420/Caf%C3%A9 Bollywood - those were the days...%2C Disc 1 in service mpd
info:
info: sendMpdCommand stop took 268 milliseconds
info: sendMpdCommand stop took 13 milliseconds
info:
info: sendMpdCommand status took 10 milliseconds
info: sendMpdCommand clear took 10 milliseconds
info:
info: ------------------------------ 11ms
info: sendMpdCommand playlistinfo took 7 milliseconds
info: sendMpdCommand add "NAS/MyNasMusic/Café Bollywood - those were the days..., Disc 1/03 Shree 420 - Pyar Hua Iqrar Hua {Shree 420}.flac" took 7 milliseconds
info: ------------------------------ 27ms
info: ------------------------------ 13ms
info: sendMpdCommand play took 10 milliseconds
info:
info:
info: sendMpdCommand status took 28 milliseconds
info: sendMpdCommand status took 2 milliseconds
info: sendMpdCommand playlistinfo took 2 milliseconds
info: ------------------------------ 38ms
info: sendMpdCommand playlistinfo took 31 milliseconds
info: ------------------------------ 71ms
process exited with code nullinfo: CoreCommandRouter::volumioGetState
info: Killing previous LiveLog session
info: Live Log process terminated: null
info:
info:
info: sendMpdCommand status took 1 milliseconds
info: ------------------------------ 15ms
info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
info: Listing playlists
info: CorePlayQueue::getQueue
info: CURURI: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/01 Sting - Prologue (If I Ever Lose My Faith in You).flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/02 Sting - Love is Stronger Than Justice (The Munificent Seven).flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/03 Sting - Fields of Gold.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/04 Sting - Heavy Cloud No Rain.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/05 Sting - She's Too Good for Me.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/06 Sting - Seven Days.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/07 Sting - Saint Augustine in Hell.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/08 Sting - It's Probably Me.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/09 Sting - Everybody Laughed But You.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/10 Sting - Shape of My Heart.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/11 Sting - Something the Boy Said.flac
info: Preloading song: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/12 Sting - Epilogue (Nothing 'Bout Me).flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/01 Sting - Prologue (If I Ever Lose My Faith in You).flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F01%20Sting%20-%20Prologue%20(If%20I%20Ever%20Lose%20My%20Faith%20in%20You).flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/01 Sting - Prologue (If I Ever Lose My Faith in You).flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/02 Sting - Love is Stronger Than Justice (The Munificent Seven).flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F02%20Sting%20-%20Love%20is%20Stronger%20Than%20Justice%20(The%20Munificent%20Seven).flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/02 Sting - Love is Stronger Than Justice (The Munificent Seven).flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/03 Sting - Fields of Gold.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F03%20Sting%20-%20Fields%20of%20Gold.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/03 Sting - Fields of Gold.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/04 Sting - Heavy Cloud No Rain.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F04%20Sting%20-%20Heavy%20Cloud%20No%20Rain.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/04 Sting - Heavy Cloud No Rain.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/05 Sting - She's Too Good for Me.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F05%20Sting%20-%20She's%20Too%20Good%20for%20Me.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/05 Sting - She's Too Good for Me.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/06 Sting - Seven Days.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F06%20Sting%20-%20Seven%20Days.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/06 Sting - Seven Days.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/07 Sting - Saint Augustine in Hell.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F07%20Sting%20-%20Saint%20Augustine%20in%20Hell.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/07 Sting - Saint Augustine in Hell.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/08 Sting - It's Probably Me.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F08%20Sting%20-%20It's%20Probably%20Me.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/08 Sting - It's Probably Me.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/09 Sting - Everybody Laughed But You.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F09%20Sting%20-%20Everybody%20Laughed%20But%20You.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/09 Sting - Everybody Laughed But You.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/10 Sting - Shape of My Heart.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F10%20Sting%20-%20Shape%20of%20My%20Heart.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/10 Sting - Shape of My Heart.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/11 Sting - Something the Boy Said.flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F11%20Sting%20-%20Something%20the%20Boy%20Said.flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/11 Sting - Something the Boy Said.flac
info: Exploding uri music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/12 Sting - Epilogue (Nothing 'Bout Me).flac in service mpd
info: ALBUMART /albumart?cacheid=235&web=Sting/Ten%20Summoner's%20Tales/extralarge&path=%2Fmnt%2FNAS%2FMyNasMusic%2FSting%20-%20Ten%20Summoner's%20Tales%2F12%20Sting%20-%20Epilogue%20(Nothing%20'Bout%20Me).flac&metadata=false
info: URI /mnt/NAS/MyNasMusic/Sting - Ten Summoner's Tales/12 Sting - Epilogue (Nothing 'Bout Me).flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/01 Sting - Prologue (If I Ever Lose My Faith in You).flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/01 Sting - Prologue (If I Ever Lose My Faith in You).flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/02 Sting - Love is Stronger Than Justice (The Munificent Seven).flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/02 Sting - Love is Stronger Than Justice (The Munificent Seven).flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/03 Sting - Fields of Gold.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/03 Sting - Fields of Gold.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/04 Sting - Heavy Cloud No Rain.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/04 Sting - Heavy Cloud No Rain.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/05 Sting - She's Too Good for Me.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/05 Sting - She's Too Good for Me.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/06 Sting - Seven Days.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/06 Sting - Seven Days.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/07 Sting - Saint Augustine in Hell.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/07 Sting - Saint Augustine in Hell.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/08 Sting - It's Probably Me.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/08 Sting - It's Probably Me.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/09 Sting - Everybody Laughed But You.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/09 Sting - Everybody Laughed But You.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/10 Sting - Shape of My Heart.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/10 Sting - Shape of My Heart.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/11 Sting - Something the Boy Said.flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/11 Sting - Something the Boy Said.flac
info: Adding Item to queue: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/12 Sting - Epilogue (Nothing 'Bout Me).flac
info: Using cached record of: music-library/NAS/MyNasMusic/Sting - Ten Summoner's Tales/12 Sting - Epilogue (Nothing 'Bout Me).flac
Tracks NAS/MyNasMusic/Sting - Ten Summoner's Tales/01 Sting - Prologue (If I Ever Lose My Faith in You).flac
info: sendMpdCommand stop took 4 milliseconds
info:
info: sendMpdCommand clear took 3 milliseconds
info:
info: ------------------------------ 2ms
info: sendMpdCommand add "NAS/MyNasMusic/Sting - Ten Summoner's Tales/01 Sting - Prologue (If I Ever Lose My Faith in You).flac" took 1 milliseconds
info:
info:
info: ------------------------------ 42ms
info: sendMpdCommand playlistinfo took 5 milliseconds
info: ------------------------------ 31ms
info: Prefetching next song
info: DOING PREFETCH IN MPD
info:
info: sendMpdCommand add "NAS/MyNasMusic/Sting - Ten Summoner's Tales/11 Sting - Something the Boy Said.flac" took 3 milliseconds
info: sendMpdCommand consume 1 took 6 milliseconds
info:
info:
info: ------------------------------ 14ms
info: CorePlayQueue::getTrack 3
info:
info: sendMpdCommand add "NAS/MyNasMusic/Sting - Ten Summoner's Tales/04 Sting - Heavy Cloud No Rain.flac" took 2 milliseconds
info: sendMpdCommand consume 1 took 2 milliseconds
info:
info:
info: sendMpdCommand playlistinfo took 1 milliseconds
info: ------------------------------ 17ms
info: CorePlayQueue::getTrack 8
info:
info: sendMpdCommand add "NAS/MyNasMusic/Sting - Ten Summoner's Tales/09 Sting - Everybody Laughed But You.flac" took 2 milliseconds
info: sendMpdCommand consume 1 took 1 milliseconds
info:
info:
info: ------------------------------ 18ms
error: peppy_screensaver: Error start PeppyMeter: Error: Command failed: /data/plugins/miscellanea/peppy_screensaver/peppymeter/run_peppymeter.sh
/data/plugins/miscellanea/peppy_screensaver/peppymeter/run_peppymeter.sh: line 8: 2347 Segmentation fault python3 volumio_peppymeter.py
info: sendMpdCommand add "NAS/MyNasMusic/Sting - Ten Summoner's Tales/05 Sting - She's Too Good for Me.flac" took 3 milliseconds
please, add ``` before your log!
Hi Sanjay74, I fear your SD card is damaged, 2347 Segmentation fault is reported for volumio_peppymeter.py on line 8, where the OS library is imported.
Hi Wheaten,
Thanks a lot. let me start over with the new card.
sure will do from next post
