Can somebody point me to a 24bit/192k file on Tidal, either through the native Tidal Android app to Volumio Connect or directly using the Volumio interface (PC or Android) and Volumio/Tidal-connect so I can test??
If I play for example Joey Alexander’s album “ORIGIN” on the native Tidal Android (which uses the same Volumio/Tidal-Connect set up on my DAC) , which is designated “Max” it only plays 44kHz/16bit**?
If I play the same track from Volumio (PC or Android) Tidal-Connect and it is designated “flac” it only plays at 44kHz/16bit ?
Where are the 24bit/192kHz files?
My DAC does not support MQA but does support up to 24/192
I am sure I am missing something really simple and maybe a setting?
Should state the obvious, but I assume you have Tidal Hi-Fi plus?
I did a search and there are a few playlists: Mostly boring music so you’re not missing out on much. (ps. Buena Vista Social Club (25th Ed) sounds good in 96kHz.
If you click on the yellow text MAX | FLAC it will toggle or show the currently playing bitrate.
I think buffering becomes an issues, personally I think 24Bit 96kHz is good enough.
premetto che ho aggiornato anche io alla versione 3.569 e che sono abbonato Tidal hifi plus.
Usando la funzione Tidal connect, da pc o da smartphone android, Volumio riproduce correttamente il flusso hires alla reale risoluzione. Il problema inizia invece quando utilizzo Tidal direttamente dal plugin di Volumio, infatti qualunque album hires provo, viene riprodotto a 44 o 48khz e non mi so spiegare il perchè.
I dont have a “Tidal Connect/Volumio”?
I can go to the song in Tidal and select the little “speaker” icon (lower-left) and re-direct the audio from “This Device” to my DAC/Tidal Connect…this is probably the same thing… so yes that is what I do. My DAC does not play MQA but I have it set as though it has MQA and I get the little yellow “MQA” but when I look at the playing resolution in Volumio interface for the same song it reports "48 KHz 24 bit. I’ve never seen 24/192. But what others are saying is that 24/192 is not really available yet?
