PCM5122: Change standard DSP to Ringing less Low Latency FIR
i’d like to see a volumio gui option to select the DSP mode utilized by the PCM5122 DAC chip and I strongly suggest setting the standard mode to
DSP program measurements & test here:
Archimago: MEASUREMENTS: HiFiBerry DAC+ Pro, PCM5122 digital filters & further thoughts on filtering…
and found it to be sounding best of all four available DSP modes.
you can currently change your DSP program by running alsamixer, to make changes permanent use sudo alsactl store and to reload the settings upon boot add a line to your /etc/rc.local:
sudo alsactl restore
right before your
exit 0 line.
Kind regards
Matthias
