I am running the Volumio PC version as multiboot.
Volumio works fine when connecting the analog output jack.
However, I’d like to use HDMI or SPDIF out.
Both are connected to my amplifier through optical output as well as through HDMI.
Both of these are tested and work with other operation systems on the same PC (Kodi,Windows,Ubuntu).
In the volumio playback options I have the option to select:
- HDA intel HDMI
- analog out
- HDMI
When switching to HDA intel HDMI I get the message “Configuration update, player succesfully restarted”.
Same thing happens when switching to Analog out and HDMI.
However after selecting the HDMI options, no sound will play.
The Analog out works though.
Also n this dropdown list I can’t see the SPDIF option.
aplay -l shows me this:
volumio@volumio:~$ aplay -l
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 1: ALC887-VD Digital [ALC887-VD Digital]
Subdevices: 1/1
So there are other devices available, just not visible in volumio.
How can I setup my volumio so that it will play through either HDMI or SPDIF?
Is there a file I can edit that will allow me to do this?
Hopefully somebody can and wants to help
Thanks.
