Dear all,
I am continuing my deep dive into the Volumio code and discovering some truly curious things
IMHO there is some extremely weird use of promises all over the place.
A promise should be used for asynchronous calls and not as a way of chaining synchronous code.
Here is a small example.
[code]CoreStateMachine.prototype.getState = function() {
var self = this;
self.commandRouter.pushConsoleMessage(’[’ + Date.now() + '] ’ + ‘CoreStateMachine::getState’);
var sService = null;
if (‘service’ in self.currentTrackBlock) {
sService = self.currentTrackBlock.service;
return libQ.resolve({
status: self.currentStatus,
position: self.currentPosition,
title: self.currentTitle,
artist: self.currentArtist,
album: self.currentAlbum,
albumart: self.currentAlbumArt,
uri: self.currentUri,
seek: self.currentSeek,
duration: self.currentDuration,
samplerate: self.currentSampleRate,
bitdepth: self.currentBitDepth,
channels: self.currentChannels,
random: self.currentRandom,
repeat: self.currentRepeat,
volume: self.currentVolume,
mute: self.currentMute,
stream: self.isStreaming,
service: sService
};[/code]
Another example
[code]CorePlayQueue.prototype.getTrackBlock = function (nStartIndex) {
this.commandRouter.pushConsoleMessage(’[’ + Date.now() + '] ’ + ‘CorePlayQueue::getTrackBlock’);
var sTargetService = this.arrayQueue[nStartIndex].service;
var nEndIndex = nStartIndex;
var nToCheck = this.arrayQueue.length - 1;
while (nEndIndex < nToCheck) {
if (this.arrayQueue[nEndIndex + 1].service !== sTargetService) {
break;
nEndIndex++;
var arrayUris = libFast.map(this.arrayQueue.slice(nStartIndex, nEndIndex + 1), function (curTrack) {
return curTrack.uri;
return libQ.resolve({service: sTargetService, uris: arrayUris, startindex: nStartIndex});
};[/code]
In both cases the code is synchronous and yet the return value is returned as the result of a resolved promise. This is downright confusing and might concievably cause wierd issues if .then methods are called a tick later or something (I don’t know if that happens).
Then later on, instead of simple code like this (which would work in exactly the same way)
self.funca();
self.funcb();
we get something like this
libQ.defer(self.funca.bind(self)).then(self.funcb.bind(self));
There are examples of code like this in there!
Anyway it just confuses the issue is less efficient and hides where asyncronous code is actually needed.
I am going through and trying to remove examples like this. I will submit some pull requests.
What are peoples opinions on this? Is there a reason for this use of promises?
