Output signal level decreased after sw upgrade
I have a Raspberry 2 with HifiBerry DAC Plus and after an upgrade to System version 2.692 (I do not know what version I had before) the output signal decreased significantly.
Please advise.
Nandor
Sort of same thing here.
The volume is on a set level and the volume control in Volumio doesn’t work anymore, not in hardware control, not in software control
I also have a HifiBerry DAC Plus. Mine sits on a Pi 3B+
René.
exactly the same problem here with the same configuration.
After restarting the system “Mixer Type” choice only None or Software.
I have the same problem, has anyone got a fix for it?
There is a known issue with volume control.
It will be investigated when the devs return from holidays.
see github.com/volumio/Volumio2/issues/1832
solved for me
Upgraded to latest version (2020.01.16.) and problem is still there.
No, I do not have problem with the volume control. It does work.
Problem is with the output level of the HifiBerry DAC+.
I use a 2x4W tube amplifier and now it is unable to amplify to the sound intensity level as it was before the volumio upgrade.
I probably would not notice this with an integrated amplifier with power of something like 2x50W.
please advise.
Hi there
Switch off the Volumio and de-energize it for at least one minute. (Take Off The Powersupply)
After that the volume was back to normal.
I only had the problem with a test system with OSA DacBerry Pro +.
The problem did not arise with the Allo BOSS DAC.
regards
rost21A
hi rost21A,
it did solve. interesting.
looks like it had nothing to do with the sw upgrade
many thanks.
nandor
