Prerequisites
Volumio Information
Volumio Version: 3.14 < Buster beta>
Hardware: pi 3
DAC: Piano DAC 2.1
When running the wizard, selecting No to I2S DAC doesn’t automatically change output device in the drop-down menu to the first device (Headphones in this case), but still shows the first device from the I2S list.
Steps to Reproduce
- Boot into Wizard
- Set I2S DACS of off
- Menu still shows (and sets) I2S DAC causing trouble later on…
Additional Information
This is using the Buster builds, but I believe this is UI issue, and shouldn’t depend on the build.
Running the wizard the second time around seems to work as expected (this is after selecting Headphones the previous time)
