I have purchased the Allo Piano and am enjoying it, but I am wondering what the output impedance is for the headphone amp.
Does anyone know?
Thanks,
JET
Does anyone know?
Thanks,
JET
JET, please don’t open single posts, but rather try to use the existing ones if they fit
I searched and no one is asking about output impedance in any other post… also I can see no particular post for general Allo Piano questions going back as far as December 2015.
How else can I ask a question if there is no activity about that topic?
Also, you appear to have deleted my Help forum question? Why is that and how can I get help for that issue?
Thanks,
JET
Hi JET, I’ve moved your previous question to this topic:
allo-piano-doesn-work-with-volumio-029-t5129.html#p24107
I will also create a topic for discussions on Allo Piano, and I will move this one to it.
Thanks!
Maybe you can find informations here!
Happy new year everyone
I checked the datasheet…they only say “Minimum load impedance is 16 Ohm”…so I assume that output Z is 1 or 2 Ohm
