Output button in Volumio
There’s an Output button at the bottom of the Volumio dashboard, between Queue and Volume. What’s that for? When I click, nothing happens and nothing comes up.
Hi Chitolimson,
in case you have got more than 1 Volumio device you can select here, which on you want to control from the UI
br
Josef
Thank you for the reply, Josh. I thought like with other streamers, I can select multiple endpoints connected to the same WiFi, like what one can do with Roon.
That means, I have to more than ONE Volumio/RPi device in other locations to make use of this feature, am I right?
