In playback, the system can freeze. Concretely it happens to me in qobuz, when I decide to change to another track. Then, the only solution I found to resume is to restart the system.
do you have FusionDSP installed?
Yes; for room correction
please install the latest version of FusionDSP
the old version has the problem you described in combination with the new MPD included in the release 3.611
Ok, I’ll do it. So plug-ins do not actualize themselves, like the operating system?
at the moment no, the plugin must be updated manually
Thank you very much for your prompt response. Have a good evening
