Tidal connect is written by the Tidal team and Spotify connect… well by a bunch of us in our free time
The Spotify client has a setting to show devices only on the local LAN, perhaps disable that?
Also you could try disabling the discovery mode, and enter your credentials via the plugin settings page.
i have no doubt that this is a networking issue (probs DNS) and not a client nor plugin issue.
local only is off and i am logged in and authorized for Spotify. Everything works if VPN is off. Only Spotify Connect is being hindered by some setting not allowing it to advertise.
You seem to still be in “discovery” mode - please go to the plugin settings page and enter your credentials to login and connect the endpoint to your account.
i’m convinced i’ve logged in - plugin interface reports all good. and i can see my spotify account within Volumio and play from within Volumio. I just can’t cast to it from spotify clients or web while vpn is connected
Spotify != Spotify Connect
Please go to the volspotifiyconnect2 plugin settings and then I believe it’s called “multi-user device” or something like that, toggle that off and enter credentials again…
Wort taking a look at your routing table, with and without the VPN active.
netstat -rn
Open VPN can be configured to route all network traffic through the VPN tunnel, and there are options for filtering multi-cast and broadcast traffic which mDNS relies on.
