Is there a way to mount OneDrive without using the plugin? Using the plugin i can only play individual songs, but Volumio will not scan and sort the files. Furthermore i also cannot play .cue files this way.
Thanks a lot!
Thanks a lot!
Really? It’s a shame, I was going to buy a Volumio Primo just for this! So I’d not have to connect an external HDD to the server, and it can pull the music from OneDrive where I have it stored. Cheap or even free cellphone apps can do it, they pull the music and index it form OneDrive! I hope they fire a way to do it.
