One Rasperry, Volumio and two I2s DAC? is that possible?
Hello again. I had thought about whether it is possible to use two output modules on a Raspberry with the help of an adapter? So more precisely an Allo Boss2 DA converter and an Allo DigiOne SPDIF. Does this work with Volumio or will it cause trouble? Does anyone here have experience? Greetings Marc
In general you could use an i2s switch to switch beetween - but you also must take care on other GIO ports that are used by the Boss2 and the DigiOne - these also must be switched
Best Regards
Josef
