Official Volumio 3 for Asus Tinkerboard
Volumio 3 downloads for Asus Tinkerboard/ Tinkerboard S were removed from the Volumio OS page due to an extreem low number of downloads.
However, official support for the Asus Tinkerboards will remain unchanged.
Updates will continue to be released with major Volumio updates.
They can be applied with OTA update or by flashing the new image on the SD-card.
Please use this topic to discuss or report board-specific bugs and other issues.
Versions and board-specific bug fixes
Only the last 3 versions of supported Tinkerboard images will be listed in this post.
New Image 3.569 with Tidal Hi-Res Flac, see post #1
new image v3.703 is available
Great to hear Volumio continues to support Tinkerboard!
Sorry to ask help about I2s DAC option missing from Playback settings. I tried 3.546 and 3.703 but till find that “I2S DAC” option missing, as Output option are only HDMI, SPDIF and onboard audio.
Look forward to solutions. Thanks!
I am waiting for a solution since12/2021. Here you find a workaround Volumio 3 Tinkerboard issues - #2 by Sgoyvaerts
May I ask for a Version 3.757 download link - thanks!
Sure, here it is
https://updates.volumio.org/tinkerboard/volumio/3.757/Volumio-3.757-2024-09-17-tinkerboard.zip
Thanx!
Do these images also support Tinkboard 2/2S and 3/3S?
no, only the original model
new stable version 3.779 is available
Is it possible to update volumio primo V1 to a newer kernel version?
Now i have
  • Version of Volumio: 3.779
  • Hostname: volumio
  • Kernel: 4.4.71+
Hi @SanKen ,
what problems do you have with the current kernel?
I don’t have. Any problem
The question is whether this is possible.
And is it possible to update to BETA version?
DEV - Test Mode doesn’t work
ASUS did not release any update for the vendor kernel of the ThinkerBoard, so it’s not possible to have it updated on Volumio
Regarding Test Mode, even if you enable it you won’t find any newer version, because 3.779 is the most recent one anyhow
Looks like Tinkerboard support has reached EOL with Version 3.804. @gkkpch one last farvor with a download link for that version. Thanx
Oh, you caught me by surprise with that. Where did you get that info from? I’m not aware of any EOL. Could be because Tinkerboard releases are a bit delayed because of an unsolved issue, but there should not be an EOL.
Thanks for the update. EOL was just a suspect and led by a lack of communication from the volumio team. Anyhow, it would be nice to have a place to get the latest tinkerboard image to enable a fresh install in case.
https://updates.volumio.org/tinkerboard/volumio/3.812/Volumio-3.812-2025-05-13-tinkerboard.zip
I tried to install 3.8.12 version on my tinkerboard original but it doesn’t boot anymoore
