I have several set-up on Volumio3 + RP4+ DAC + official 7" touchscreen.
Recently I am unable to use the touchscreen on one of those systems. It doesn’t display anything, jsut as if it was not running.
I have cheked to power supply, the connexion, the screen itself…
Can’t find a way to debug this.
I am wondering if I forgot a simple parameter or equivalent that would disable the screen…
B
I will desinstall and reinstall the plugin. I see nothing at all. Is there a way to see if the screen is actually working even if not displaying anything?
@Baptiste normal you will see something on your screen it sounds like or a broken screen,
or the dsi cable lose / power cable but what simonE says test it on a other device and see if it shows there
Hi there,
I will dismount the screen and test it on another set-up to see if it is working or not.
I have tested the cables incl a direct power supply from the PI with no success.
I am afraid it is broken…
