I connected my Odroid N2 (latest Volumio 3.379) to a Lenovo 1440x900 screen using the 3.3.5 version of the touchscreen plugin. The Odroid did not recognize the screen.
Using the older 3.3.1 version, the Odroid recognized the screen just fine.
I am puzzled that there is a difference in this respect between the two versions of the plugin.
Is Volumio’s boot screen displayed?
Do you see an error message when you enable the plugin? If so, what’s the message?
Nothing is displayed on the screen. No error message when installing the plugin.
Remote access via tablet works
So you don’t even see Volumio’s boot screen?
There is no boot screen present on community portings
Ok, should there be text lines displayed when the system boots?
Please connect to Volumio via SSH (SSH - Volumio Documentation) and post the output of
cat /var/log/Xorg.0.log
No, there is no boot log.
Without the touchscreen plugin, you will only see the login prompt after boot has finished. Before that, the screen is blank.
@gkkpch Thanks for the info.
@jacobacci Do you see the mentioned login prompt after Volumio has booted?
To compare, with a 1920x1080 monitor, Xorg.0.log would look like this:
[ 15.424]
X.Org X Server 1.20.4
[ 15.424] Build Operating System: Linux 4.19.0-18-armmp-lpae armv7l Debian
[ 15.424] Current Operating System: Linux n2-office 4.9.241+ #7 SMP PREEMPT Sat Apr 9 15:06:53 CEST 2022 aarch64
[ 15.424] Kernel command line: imgpart=UUID=b7f12066-a6f7-4571-9909-fd20bd6c88dd bootpart=UUID=A2F6-C4EA datapart=UUID=8332ea4f-d8b1-4c5c-91f3-df5bdd8d16d1 imgfile=/volumio_current.sqsh bootconfig=boot.ini loglevel=0 hwdevice=Odroid-N2 bootdelay=5 gpiopower=479 rootwait rw console=ttyS0,115200n8 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 monitor_onoff=false logo=osd0,loaded hdmitx=cec3f sdrmode=auto
[ 15.424] Build Date: 18 December 2021 09:05:36AM
[ 15.424] xorg-server 2:1.20.4-1+deb10u4 (https://www.debian.org/support)
[ 15.424] Current version of pixman: 0.36.0
[ 15.424] Before reporting problems, check http://wiki.x.org
[ 15.424] Markers: (--) probed, (**) from config file, (==) default setting,
[ 15.424] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 27 09:36:27 2022
[ 15.426] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 15.428] (==) No Layout section. Using the first Screen section.
[ 15.428] (==) No screen section available. Using defaults.
[ 15.428] (**) |-->Screen "Default Screen Section" (0)
[ 15.428] (**) | |-->Monitor "<default monitor>"
[ 15.428] (==) No monitor specified for screen "Default Screen Section".
[ 15.428] (==) Automatically adding devices
[ 15.428] (==) Automatically enabling devices
[ 15.428] (==) Automatically adding GPU devices
[ 15.429] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 15.431] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 15.431] Entry deleted from font path.
[ 15.433] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 15.433] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 15.433] (II) The server relies on udev to provide the list of input devices.
[ 15.433] (II) Loader magic: 0xaac44f98
[ 15.433] (II) Module ABI versions:
[ 15.433] X.Org ANSI C Emulation: 0.4
[ 15.433] X.Org Video Driver: 24.0
[ 15.433] X.Org XInput driver : 24.1
[ 15.433] X.Org Server Extension : 10.0
[ 15.434] (--) using VT number 2
[ 15.434] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 15.434] (II) no primary bus or device found
[ 15.434] (II) LoadModule: "glx"
[ 15.435] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 15.452] (II) Module glx: vendor="X.Org Foundation"
[ 15.452] compiled for 1.20.4, module version = 1.0.0
[ 15.452] ABI class: X.Org Server Extension, version 10.0
[ 15.452] (==) Matched modesetting as autoconfigured driver 0
[ 15.452] (==) Matched fbdev as autoconfigured driver 1
[ 15.452] (==) Assigned the driver to the xf86ConfigLayout
[ 15.452] (II) LoadModule: "modesetting"
[ 15.454] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 15.456] (II) Module modesetting: vendor="X.Org Foundation"
[ 15.456] compiled for 1.20.4, module version = 1.20.4
[ 15.456] Module class: X.Org Video Driver
[ 15.456] ABI class: X.Org Video Driver, version 24.0
[ 15.456] (II) LoadModule: "fbdev"
[ 15.456] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 15.456] (II) Module fbdev: vendor="X.Org Foundation"
[ 15.456] compiled for 1.20.0, module version = 0.5.0
[ 15.457] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 15.457] (II) FBDEV: driver for framebuffer: fbdev
[ 15.463] (WW) Falling back to old probe method for modesetting
[ 15.464] (EE) open /dev/dri/card0: No such file or directory
[ 15.464] (WW) Falling back to old probe method for fbdev
[ 15.464] (II) Loading sub module "fbdevhw"
[ 15.464] (II) LoadModule: "fbdevhw"
[ 15.464] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 15.465] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 15.465] compiled for 1.20.4, module version = 0.0.2
[ 15.465] ABI class: X.Org Video Driver, version 24.0
[ 15.465] (II) FBDEV(0): using default device
[ 15.465] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 15.465] (II) FBDEV(0): Creating default Display subsection in Screen section
[ 15.465] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 15.465] (==) FBDEV(0): RGB weight 888
[ 15.465] (==) FBDEV(0): Default visual is TrueColor
[ 15.465] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 15.465] (II) FBDEV(0): hardware: OSD FB (video memory: 77312kB)
[ 15.465] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 15.465] (II) FBDEV(0): checking modes against framebuffer device...
[ 15.465] (II) FBDEV(0): checking modes against monitor...
[ 15.465] (II) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[ 15.465] (**) FBDEV(0): Built-in mode "current"
[ 15.465] (==) FBDEV(0): DPI set to (96, 96)
[ 15.465] (II) Loading sub module "fb"
[ 15.465] (II) LoadModule: "fb"
[ 15.465] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 15.468] (II) Module fb: vendor="X.Org Foundation"
[ 15.468] compiled for 1.20.4, module version = 1.0.0
[ 15.468] ABI class: X.Org ANSI C Emulation, version 0.4
[ 15.468] (**) FBDEV(0): using shadow framebuffer
[ 15.468] (II) Loading sub module "shadow"
[ 15.468] (II) LoadModule: "shadow"
[ 15.468] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 15.470] (II) Module shadow: vendor="X.Org Foundation"
[ 15.470] compiled for 1.20.4, module version = 1.1.0
[ 15.470] ABI class: X.Org ANSI C Emulation, version 0.4
[ 15.470] (II) UnloadModule: "modesetting"
[ 15.470] (II) Unloading modesetting
[ 15.496] (==) FBDEV(0): Backing store enabled
[ 15.497] (==) FBDEV(0): DPMS enabled
[ 15.497] (II) Initializing extension Generic Event Extension
[ 15.497] (II) Initializing extension SHAPE
[ 15.498] (II) Initializing extension MIT-SHM
[ 15.498] (II) Initializing extension XInputExtension
[ 15.499] (II) Initializing extension XTEST
[ 15.500] (II) Initializing extension BIG-REQUESTS
[ 15.500] (II) Initializing extension SYNC
[ 15.501] (II) Initializing extension XKEYBOARD
[ 15.502] (II) Initializing extension XC-MISC
[ 15.502] (II) Initializing extension SECURITY
[ 15.503] (II) Initializing extension XFIXES
[ 15.503] (II) Initializing extension RENDER
[ 15.504] (II) Initializing extension RANDR
[ 15.505] (II) Initializing extension COMPOSITE
[ 15.505] (II) Initializing extension DAMAGE
[ 15.506] (II) Initializing extension MIT-SCREEN-SAVER
[ 15.506] (II) Initializing extension DOUBLE-BUFFER
[ 15.507] (II) Initializing extension RECORD
[ 15.507] (II) Initializing extension DPMS
[ 15.508] (II) Initializing extension Present
[ 15.509] (II) Initializing extension DRI3
[ 15.509] (II) Initializing extension X-Resource
[ 15.509] (II) Initializing extension XVideo
[ 15.510] (II) Initializing extension XVideo-MotionCompensation
[ 15.510] (II) Initializing extension SELinux
[ 15.510] (II) SELinux: Disabled on system
[ 15.510] (II) Initializing extension GLX
[ 15.510] (II) AIGLX: Screen 0 is not DRI2 capable
[ 15.748] (II) IGLX: Loaded and initialized swrast
[ 15.748] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 15.748] (II) Initializing extension XFree86-VidModeExtension
[ 15.748] (II) Initializing extension XFree86-DGA
[ 15.749] (II) Initializing extension XFree86-DRI
[ 15.749] (II) Initializing extension DRI2
[ 15.842] (II) config/udev: Adding input device gpio_keypad (/dev/input/event0)
[ 15.842] (**) gpio_keypad: Applying InputClass "libinput keyboard catchall"
[ 15.842] (II) LoadModule: "libinput"
[ 15.843] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 15.856] (II) Module libinput: vendor="X.Org Foundation"
[ 15.856] compiled for 1.20.4, module version = 0.28.2
[ 15.856] Module class: X.Org XInput Driver
[ 15.856] ABI class: X.Org XInput driver, version 24.1
[ 15.856] (II) Using input driver 'libinput' for 'gpio_keypad'
[ 15.856] (**) gpio_keypad: always reports core events
[ 15.856] (**) Option "Device" "/dev/input/event0"
[ 15.856] (**) Option "_source" "server/udev"
[ 15.866] (II) event0 - gpio_keypad: is tagged by udev as: Keyboard
[ 15.866] (II) event0 - gpio_keypad: device is a keyboard
[ 15.866] (II) event0 - gpio_keypad: device removed
[ 15.900] (**) Option "config_info" "udev:/sys/devices/platform/ff800000.gpio_keypad/input/input0/event0"
[ 15.900] (II) XINPUT: Adding extended input device "gpio_keypad" (type: KEYBOARD, id 6)
[ 15.900] (**) Option "xkb_model" "pc105"
[ 15.901] (**) Option "xkb_layout" "us"
[ 15.902] (II) event0 - gpio_keypad: is tagged by udev as: Keyboard
[ 15.902] (II) event0 - gpio_keypad: device is a keyboard
[ 15.903] (II) config/udev: Adding input device cec_input (/dev/input/event1)
[ 15.903] (**) cec_input: Applying InputClass "libinput keyboard catchall"
[ 15.903] (II) Using input driver 'libinput' for 'cec_input'
[ 15.903] (**) cec_input: always reports core events
[ 15.903] (**) Option "Device" "/dev/input/event1"
[ 15.903] (**) Option "_source" "server/udev"
[ 15.904] (II) event1 - cec_input: is tagged by udev as: Keyboard
[ 15.904] (II) event1 - cec_input: device is a keyboard
[ 15.904] (II) event1 - cec_input: device removed
[ 15.936] (**) Option "config_info" "udev:/sys/devices/virtual/input/input1/event1"
[ 15.936] (II) XINPUT: Adding extended input device "cec_input" (type: KEYBOARD, id 7)
[ 15.936] (**) Option "xkb_model" "pc105"
[ 15.936] (**) Option "xkb_layout" "us"
[ 15.937] (II) event1 - cec_input: is tagged by udev as: Keyboard
[ 15.937] (II) event1 - cec_input: device is a keyboard
But… the screen remains blank, no local UI.
This is strange, I don’t use it, but as far as I remember it was working when I developed the image.
Just ran the same test, and indeed the screen remains empty.
During boot the login prompt is visible, but then the screen turns grey.
Odroid N2+
Volumio: V3.379
Plugin: V3.3.5
cat /var/log/Xorg.0.log as requested:
volumio@volumio-n2:~$ cat /var/log/Xorg.0.log
[ 24.479]
[ 24.479] Build Operating System: Linux 4.19.0-18-armmp-lpae armv7l Debian
[ 24.479] Current Operating System: Linux volumio-n2 4.9.241+ #7 SMP PREEMPT Sat Apr 9 15:06:53 CEST 2022 aarch64
[ 24.479] Kernel command line: imgpart=UUID=6ef95bd7-5a8d-43cb-8c3c-60636192475e bootpart=UUID=FD06-2167 datapart=UUID=b252171a-8937-4162-835f-3d9bb865c7a6 imgfile=/volumio_current.sqsh bootconfig=boot.ini loglevel=0 hwdevice=Odroid-N2 bootdelay=5 gpiopower=479 rootwait rw console=ttyS0,115200n8 no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1908 max_freq_a73=2208 maxcpus=6 voutmode=hdmi modeline=1920,1080,148500,67500,60,1920,2008,2052,2200,1080,1084,1089,1125,1,1,1 disablehpd=false cvbscable= overscan=100 monitor_onoff=false logo=osd0,loaded hdmitx=cec3f sdrmode=auto
[ 24.479] Build Date: 18 December 2021 09:05:36AM
[ 24.479] xorg-server 2:1.20.4-1+deb10u4 (https://www.debian.org/support)
[ 24.479] Current version of pixman: 0.36.0
[ 24.479] Before reporting problems, check http://wiki.x.org
[ 24.479] Markers: (--) probed, (**) from config file, (==) default setting,
[ 24.479] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Oct 16 11:21:45 2022
[ 24.491] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 24.501] (==) No Layout section. Using the first Screen section.
[ 24.501] (==) No screen section available. Using defaults.
[ 24.501] (**) |-->Screen "Default Screen Section" (0)
[ 24.501] (**) | |-->Monitor "<default monitor>"
[ 24.501] (==) No monitor specified for screen "Default Screen Section".
[ 24.502] (==) Automatically adding devices
[ 24.502] (==) Automatically enabling devices
[ 24.502] (==) Automatically adding GPU devices
[ 24.508] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 24.519] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 24.519] Entry deleted from font path.
[ 24.531] (==) FontPath set to:
built-ins
[ 24.531] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 24.531] (II) The server relies on udev to provide the list of input devices.
[ 24.531] (II) Loader magic: 0xab211f98
[ 24.531] (II) Module ABI versions:
[ 24.531] X.Org ANSI C Emulation: 0.4
[ 24.531] X.Org Video Driver: 24.0
[ 24.531] X.Org XInput driver : 24.1
[ 24.531] X.Org Server Extension : 10.0
[ 24.532] (--) using VT number 2
[ 24.532] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 24.532] (II) no primary bus or device found
[ 24.532] (II) LoadModule: "glx"
[ 24.536] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 24.602] (II) Module glx: vendor="X.Org Foundation"
[ 24.602] compiled for 1.20.4, module version = 1.0.0
[ 24.602] ABI class: X.Org Server Extension, version 10.0
[ 24.603] (==) Matched modesetting as autoconfigured driver 0
[ 24.603] (==) Matched fbdev as autoconfigured driver 1
[ 24.603] (==) Assigned the driver to the xf86ConfigLayout
[ 24.603] (II) LoadModule: "modesetting"
[ 24.603] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 24.608] (II) Module modesetting: vendor="X.Org Foundation"
[ 24.608] compiled for 1.20.4, module version = 1.20.4
[ 24.608] Module class: X.Org Video Driver
[ 24.608] ABI class: X.Org Video Driver, version 24.0
[ 24.608] (II) LoadModule: "fbdev"
[ 24.608] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 24.611] (II) Module fbdev: vendor="X.Org Foundation"
[ 24.611] compiled for 1.20.0, module version = 0.5.0
[ 24.611] Module class: X.Org Video Driver
[ 24.611] ABI class: X.Org Video Driver, version 24.0
[ 24.611] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 24.611] (II) FBDEV: driver for framebuffer: fbdev
[ 24.617] (WW) Falling back to old probe method for modesetting
[ 24.617] (EE) open /dev/dri/card0: No such file or directory
[ 24.617] (WW) Falling back to old probe method for fbdev
[ 24.617] (II) Loading sub module "fbdevhw"
[ 24.617] (II) LoadModule: "fbdevhw"
[ 24.618] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 24.619] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 24.619] compiled for 1.20.4, module version = 0.0.2
[ 24.619] ABI class: X.Org Video Driver, version 24.0
[ 24.619] (II) FBDEV(0): using default device
[ 24.619] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 24.619] (II) FBDEV(0): Creating default Display subsection in Screen section
[ 24.619] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 24.619] (==) FBDEV(0): RGB weight 888
[ 24.619] (==) FBDEV(0): Default visual is TrueColor
[ 24.619] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 24.619] (II) FBDEV(0): hardware: OSD FB (video memory: 77312kB)
[ 24.619] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 24.619] (II) FBDEV(0): checking modes against framebuffer device...
[ 24.619] (II) FBDEV(0): checking modes against monitor...
[ 24.619] (II) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
[ 24.619] (**) FBDEV(0): Built-in mode "current"
[ 24.619] (==) FBDEV(0): DPI set to (96, 96)
[ 24.619] (II) Loading sub module "fb"
[ 24.619] (II) LoadModule: "fb"
[ 24.619] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 24.631] (II) Module fb: vendor="X.Org Foundation"
[ 24.631] compiled for 1.20.4, module version = 1.0.0
[ 24.631] ABI class: X.Org ANSI C Emulation, version 0.4
[ 24.631] (**) FBDEV(0): using shadow framebuffer
[ 24.631] (II) Loading sub module "shadow"
[ 24.631] (II) LoadModule: "shadow"
[ 24.631] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 24.635] (II) Module shadow: vendor="X.Org Foundation"
[ 24.635] compiled for 1.20.4, module version = 1.1.0
[ 24.635] ABI class: X.Org ANSI C Emulation, version 0.4
[ 24.635] (II) UnloadModule: "modesetting"
[ 24.635] (II) Unloading modesetting
[ 24.677] (==) FBDEV(0): Backing store enabled
[ 24.678] (==) FBDEV(0): DPMS enabled
[ 24.678] (II) Initializing extension Generic Event Extension
[ 24.678] (II) Initializing extension SHAPE
[ 24.678] (II) Initializing extension MIT-SHM
[ 24.679] (II) Initializing extension XInputExtension
[ 24.679] (II) Initializing extension XTEST
[ 24.679] (II) Initializing extension BIG-REQUESTS
[ 24.679] (II) Initializing extension SYNC
[ 24.680] (II) Initializing extension XKEYBOARD
[ 24.680] (II) Initializing extension XC-MISC
[ 24.680] (II) Initializing extension SECURITY
[ 24.680] (II) Initializing extension XFIXES
[ 24.681] (II) Initializing extension RENDER
[ 24.681] (II) Initializing extension RANDR
[ 24.681] (II) Initializing extension COMPOSITE
[ 24.682] (II) Initializing extension DAMAGE
[ 24.682] (II) Initializing extension MIT-SCREEN-SAVER
[ 24.682] (II) Initializing extension DOUBLE-BUFFER
[ 24.682] (II) Initializing extension RECORD
[ 24.683] (II) Initializing extension DPMS
[ 24.683] (II) Initializing extension Present
[ 24.683] (II) Initializing extension DRI3
[ 24.683] (II) Initializing extension X-Resource
[ 24.683] (II) Initializing extension XVideo
[ 24.683] (II) Initializing extension XVideo-MotionCompensation
[ 24.684] (II) Initializing extension SELinux
[ 24.684] (II) SELinux: Disabled on system
[ 24.684] (II) Initializing extension GLX
[ 24.684] (II) AIGLX: Screen 0 is not DRI2 capable
[ 25.884] (II) IGLX: Loaded and initialized swrast
[ 25.884] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 25.884] (II) Initializing extension XFree86-VidModeExtension
[ 25.885] (II) Initializing extension XFree86-DGA
[ 25.885] (II) Initializing extension XFree86-DRI
[ 25.885] (II) Initializing extension DRI2
[ 26.075] (II) config/udev: Adding input device gpio_keypad (/dev/input/event0)
[ 26.075] (**) gpio_keypad: Applying InputClass "libinput keyboard catchall"
[ 26.075] (II) LoadModule: "libinput"
[ 26.076] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 26.111] (II) Module libinput: vendor="X.Org Foundation"
[ 26.111] compiled for 1.20.4, module version = 0.28.2
[ 26.111] Module class: X.Org XInput Driver
[ 26.111] ABI class: X.Org XInput driver, version 24.1
[ 26.111] (II) Using input driver 'libinput' for 'gpio_keypad'
[ 26.112] (**) gpio_keypad: always reports core events
[ 26.112] (**) Option "Device" "/dev/input/event0"
[ 26.112] (**) Option "_source" "server/udev"
[ 26.143] (II) event0 - gpio_keypad: is tagged by udev as: Keyboard
[ 26.143] (II) event0 - gpio_keypad: device is a keyboard
[ 26.144] (II) event0 - gpio_keypad: device removed
[ 26.168] (**) Option "config_info" "udev:/sys/devices/platform/ff800000.gpio_keypad/input/input0/event0"
[ 26.168] (II) XINPUT: Adding extended input device "gpio_keypad" (type: KEYBOARD, id 6)
[ 26.168] (**) Option "xkb_model" "pc105"
[ 26.168] (**) Option "xkb_layout" "us"
[ 26.171] (II) event0 - gpio_keypad: is tagged by udev as: Keyboard
[ 26.171] (II) event0 - gpio_keypad: device is a keyboard
[ 26.172] (II) config/udev: Adding input device cec_input (/dev/input/event1)
[ 26.172] (**) cec_input: Applying InputClass "libinput keyboard catchall"
[ 26.172] (II) Using input driver 'libinput' for 'cec_input'
[ 26.172] (**) cec_input: always reports core events
[ 26.172] (**) Option "Device" "/dev/input/event1"
[ 26.172] (**) Option "_source" "server/udev"
[ 26.174] (II) event1 - cec_input: is tagged by udev as: Keyboard
[ 26.174] (II) event1 - cec_input: device is a keyboard
[ 26.174] (II) event1 - cec_input: device removed
[ 26.192] (**) Option "config_info" "udev:/sys/devices/virtual/input/input1/event1"
[ 26.192] (II) XINPUT: Adding extended input device "cec_input" (type: KEYBOARD, id 7)
[ 26.192] (**) Option "xkb_model" "pc105"
[ 26.192] (**) Option "xkb_layout" "us"
[ 26.194] (II) event1 - cec_input: is tagged by udev as: Keyboard
[ 26.194] (II) event1 - cec_input: device is a keyboard
I did a Uninstall and tried to reinstall, but the plugin errored out:
http://logs.volumio.org/volumio/r4OIXrz.html
not plain black, very dark grey.
Then I guess it is an issue with chromium. Please post the results of
systemctl status -l volumio-kiosk
chromium-browser -version
and
ls -al /usr/bin/chromium*
Sorry unable to do, as the plugin keeps failing to install after my 1st removal.
get stuck on below, when trying to remove it again:
@Wheaten Yes, I saw that the re-install failed on your system. Therefore my last my last post was intended for @gkkpch… was not clear enough though.
Successful install of V3.3.1, but here it’s the same. Dark background.
trying to upgrade to V3.3.5:
And the installer crashed again…
The log you linked in post 12 shows that the Touch Display’s install script fails on linking “/usr/bin/chromium” to “/usr/bin/chromium-browser”. This is why installing the plugin failed. ATM I don’t see why this happened…
Edit: I believe the issue is that on updating the plugin to 3.3.5 from an older version, linking “/usr/bin/chromium” to “/usr/bin/chromium-browser” fails, because the link is already there. Since version 3.3.3beta the install script detects this error and cancels the installation. I will do a PR for a new version of the plugin ASAP.
In the meanwhile instead of updating the plugin I recommend to uninstall it and then install the new version.
Note: This issue only affects non-Pi system.
