I just ordered, yet another board… the ODROID C4 and I am wondering if there is support for it…i.e. using the C2 image???
I have also ordered the ODROID HIFI Plus… will this work as a supported device?
Have a look over here. Seems gkkpch is currently working on it and has already something to try out.
Thank you!
HiFi DAC boards are not supported yet, Hardkernel is still working on some compatibility issues. I will update/enhance DAC support when HK fixes it.
