could people with usb audio issues (crackling, pops, clicks, not recognized)) on Odroid C2 please reply with DAC type and the output of
lsusb -t
lsusb -v
This will help me clearing the newly identified usb driver issues with Hardkernel.
-Gé-
lsusb -t
lsusb -v
-Gé-
Hi gkkpch and thanks for your work.
My DAC is Burson Audio Conductor with CM6631A USB receiver.
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=rtl8812au, 480M
|__ Port 3: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 4, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 480M
lsusb -v
Bus 001 Device 004: ID 0d8c:0004 C-Media Electronics, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x0d8c C-Media Electronics, Inc.
idProduct 0x0004
bcdDevice 2.09
iManufacturer 1 C-Media Electronics Inc.
iProduct 2 USB2.0 High-Speed True HD Audio
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 245
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 0
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 10
wTotalLength 256
bmControl 0x00
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bCSourceID 18
bNrChannels 0
bmChannelConfig 0x00000000
bmControls 0x0040
Cluster Control (read-only)
iChannelNames 0
iTerminal 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 7
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 13
bCSourceID 18
bmControls 0x0004
Connector Control (read-only)
iTerminal 0
bLength 18
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 13
bSourceID 1
bmaControls( 0) 0x00000003
Mute Control (read/write)
bmaControls( 1) 0x00000000
bmaControls( 2) 0x00000000
iFeature 0
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 18
bmAttributes 0x03 Internal programmable Clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x8f EP 15 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0006 1x 6 bytes
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 4 Speaker
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 1
bmControls 0x05
Active Alternate Setting Control (read-only)
Valid Alternate Setting Control (read-only)
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 2
bmChannelConfig 0x00000003
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0068 1x 104 bytes
bInterval 1
AudioControl Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 1
bmControls 0x05
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 3
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x009c 1x 156 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 8
bDescriptorType 11
bFirstInterface 2
bInterfaceCount 1
bFunctionClass 3 Human Interface Device
bFunctionSubClass 0
bFunctionProtocol 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 50
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 4
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0001
Self Powered
Bus 001 Device 003: ID 7392:a812 Edimax Technology Co., Ltd
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x7392 Edimax Technology Co., Ltd
idProduct 0xa812
bcdDevice 2.00
iManufacturer 1 Realtek
iProduct 2 Edimax AC600 USB
iSerial 3 00e04c000001
bLength 9
bDescriptorType 2
wTotalLength 60
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 6
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 Edimax AC600 USB
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x09 EP 9 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 12
bNumDeviceCaps 1
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
HIRD Link Power Management (LPM) Supported
Self Powered
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idVendor 0x05e3 Genesys Logic, Inc.
idProduct 0x0610 4-port hub
bcdDevice 32.98
iManufacturer 0
iProduct 1 USB2.0 Hub
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceProtocol 1 Single TT
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 4
wHubCharacteristic 0x00e0
Ganged power switching
Ganged overcurrent protection
TT think time 32 FS bits
Port indicators
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 100 milli Ampere
DeviceRemovable 0x00
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Port 2: 0000.0100 power
Port 3: 0000.0503 highspeed power enable connect
Port 4: 0000.0100 power
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.14
iManufacturer 3 Linux 3.14.29-21-ARCH dwc_otg_hcd
iProduct 2 DWC OTG Controller
iSerial 1 dwc2_b
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0008
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 1 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
Hub Port Status:
can't get device qualifier: Resource temporarily unavailable
Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 3.14
iSerial 1 dwc2_a
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Port 1: 0000.0000
Self Powered
Hi.
I have the same problems (pops and clicks) on Odroid C2 as those described in usb-waveio-xmos-clicks-odroid-t5299-30.html. I am usin an external USB audio interface Behringer UMC 202HD.
I have to note, I have not tried the Volumio yet. Please, ignore this if you were only concerned about the Volumio specific reports. Would you point me to an existing C2 bug report/discussion then?
The output is from Libeelec, but I’ve had similar problems with official Odroid C2 Ubuntu image.
Odroid_C2.aarch64-7.90.010, Linux odroid-c2 3.14.29 #1 SMP PREEMPT Thu Dec 22 01:03:44 GMT 2016 aarch64 GNU/Linux
odroid-c2:~ # lsusb -t
|__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 2: Dev 5, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 2: Dev 5, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 3: Dev 6, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 6, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 6, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 6, If 3, Class=Application Specific Interface, Driver=, 480M
[code]Bus 001 Device 006: ID 1397:0507 BEHRINGER International GmbH
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
idVendor 0x1397 BEHRINGER International GmbH
idProduct 0x0507
bcdDevice 1.12
iManufacturer 1 BEHRINGER
iProduct 3 UMC202HD 192k
iSerial 0
bNumConfigurations 2
bLength 9
bDescriptorType 2
wTotalLength 333
bNumInterfaces 4
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionSubClass 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
iInterface 3 UMC202HD 192k
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 8
wTotalLength 119
bmControl 0x00
bLength 8
bDescriptorType 36
bClockID 41
bmControls 0x07
bAssocTerminal 0
iClockSource 9 UMC202HD 192k Internal Clock
bLength 8
bDescriptorType 36
bDescriptorSubtype 11 (CLOCK_SELECTOR)
bUnitID 40
bNrInPins 1
baCSourceID( 0) 41
bmControls 0x03
Clock Selector Control (read/write)
iClockSelector 13 Out 1
bLength 17
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmControls 0x0000
iChannelNames 13 Out 1
iTerminal 6 UMC202HD 192k Output
bLength 18
bDescriptorType 36
bUnitID 10
bSourceID 2
bmaControls( 0) 0x0000000f
Volume Control (read/write)
bmaControls( 1) 0x0000000f
bmaControls( 2) 0x0000000f
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 20
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 1
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmControls 0x0000
iChannelNames 15 In 1
iTerminal 0
bLength 18
bDescriptorType 36
bUnitID 11
bSourceID 1
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 22
bAssocTerminal 0
bSourceID 11
bCSourceID 40
bmControls 0x0000
iTerminal 7 UMC202HD 192k Input
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 4 UMC202HD 192k Output
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x00c8 1x 200 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 2 Decoded PCM samples
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0064 1x 100 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 5 UMC202HD 192k Input
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
iInterface 10 UMC202HD 192k DFU
Device Firmware Upgrade Interface Descriptor:
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Manifestation Tolerant
Upload Supported
Download Supported
wDetachTimeout 250 milliseconds
wTransferSize 64 bytes
bcdDFUVersion 1.10
bLength 9
bDescriptorType 2
wTotalLength 333
bNumInterfaces 4
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionSubClass 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 8
wTotalLength 119
bmControl 0x00
bLength 8
bDescriptorType 36
bClockID 41
bmControls 0x07
bAssocTerminal 0
bLength 8
bDescriptorType 36
bUnitID 40
bNrInPins 1
baCSourceID( 0) 41
bmControls 0x03
bLength 17
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmControls 0x0000
bLength 18
bDescriptorType 36
bUnitID 10
bSourceID 2
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 20
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 1
bAssocTerminal 0
bCSourceID 40
bNrChannels 2
bmControls 0x0000
iTerminal 0
bLength 18
bDescriptorType 36
bUnitID 11
bSourceID 1
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 22
bAssocTerminal 0
bSourceID 11
bCSourceID 40
bmControls 0x0000
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Upload Supported
Download Supported
bcdDFUVersion 1.10
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 224 Wireless
bDeviceSubClass 1 Radio Frequency
bDeviceProtocol 1 Bluetooth
bMaxPacketSize0 16
idVendor 0x0a12 Cambridge Silicon Radio, Ltd
idProduct 0x0001 Bluetooth Dongle (HCI mode)
bcdDevice 1.34
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 108
bNumInterfaces 2
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 224 Wireless
bInterfaceSubClass 1 Radio Frequency
bInterfaceProtocol 1 Bluetooth
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0009 1x 9 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0011 1x 17 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
(Bus Powered)
Bus 001 Device 003: ID 1058:082a Western Digital Technologies, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1058 Western Digital Technologies, Inc.
idProduct 0x082a
bcdDevice 10.12
iManufacturer 1 Western Digital
iProduct 2 My Passport 082A
iSerial 5 57584431413734433936564A
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
bLength 7
bDescriptorType 16
bmAttributes 0x00000f0e
BESL Link Power Management (LPM) Supported
BESL value 3840 us
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 32 micro seconds
(Bus Powered)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 32.98
iManufacturer 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 4
Port indicators
Hub Port Status:
Port 2: 0000.0103 power enable connect
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 3.14
iManufacturer 3 Linux 3.14.29 dwc_otg_hcd
iSerial 1 dwc2_b
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 3.14
iSerial 1 dwc2_a
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Port 1: 0000.0000
Self Powered[/code]
Changing IRQ63 affinity to another CPU almost solves the issue. I still can hear pops and clicks during 44K/16 FLAC playback if I load the system and/or Kodi UI (by endless scrolling through the songs list, for example). But without affinity change it is much worse. Have not tried the OTG yet.
I would post this in the C2 LibreElec thread on the HK Odroid forum, libreelec has been configured completely different plus you should get direct support there. There is not much I can contribute with LibreElec as I don’t use it, sorry.
I’m on an Odroid C2 with a dragonfly red attached with Volumio 2.03
Non-stop crackling. Here’s my output:
volumio@volumio:~$ lsusb -t
|__ Port 2: Dev 5, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 2: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 3: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
volumio@volumio:~$ lsusb -v
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Couldn’t open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x046d Logitech, Inc.
idProduct 0xc52b Unifying Receiver
bcdDevice 12.01
iManufacturer 1
iProduct 2
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 84
bNumInterfaces 3
iConfiguration 4
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 98mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 59
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 8
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2 Mouse
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 148
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 2
bLength 9
bDescriptorType 4
bInterfaceNumber io: ~v
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 98
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 2
Bus 001 Device 005: ID 21b4:0082
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x21b4
idProduct 0x0082
bcdDevice 1.01
iManufacturer 1
iProduct 2
iSerial 3
bLength 9
bDescriptorType 2
wTotalLength 127
bNumInterfaces 2
bConfigurationValue 2
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 24mA
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 36
bcdADC 1.00
wTotalLength 39
bInCollection 1
baInterfaceNr( 0) 2
bLength 12
bDescriptorType 36
bTerminalID 9
bAssocTerminal 0
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front ®
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bUnitID 5
bSourceID 9
bControlSize 2
bmaControls( 0) 0x03
Mute Control
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bSourceID 5
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 9
bDelay 1 frames
wFormatTag 1 PCM
bLength 20
bDescriptorType 36
bNrChannels 2
bSubframeSize 3
bBitResolution 24
bSamFreqType 4 Discrete
tSamFreq[ 0] 44100
tSamFreq[ 1] 48000
tSamFreq[ 2] 88200
tSamFreq[ 3] 96000
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x024c 1x 588 bytes
bInterval 1
bRefresh 0
bSynchAddress 131
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
wLockDelay 0 Undefined
bLength 9
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0003 1x 3 bytes
bInterval 1
bRefresh 5
bSynchAddress 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bMaxPacketSize0 64
bcdDevice 32.98
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 0 Unused
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 3.14
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 3.14
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Are there any news on the issue?
I still have problems (many pops and clicks - Odroid C2 => USB => DAC Burson Conductor), even with the new version 2.129.
No, unfortunately not yet.
Basically it is Hardkernel who needs to offer a solution, we can only tune a little.
I’m hoping for the mainline kernel, this is where we will have re-written usb drivers.
But, due to the work on other boards I might have some things to improve, it will take a little time though ![]()
currently i compare some one platine Hardware running KODI as our MediaCenter:
I made a Blog for this, please scroll down a little bit until the Odroid C2 section comes with same Audio Issues as here:
https://mytec-home.de/multimedia/kodi-mediacenter-pc-vs-odroid-c2-vs-raspberry-3
I also made few tests until yet, all without success.
I run a current LibreElec, sound via HDMI without any issues, sound via USB Odroid SPDIF http://amzn.to/2jWS2Zn with many cracks and stops.
With same USB Audio converter, a Raspberry 3 is without issues.
Some news here?
Yes and no.
These are usb driver issues, but do not expect any further improvement with the currently supported kernel 3.14.x
That is a dead end now that mainline kernel support for the C2 is on its way (see the Hardkernel forums).
Though support seems fairly stable, I cannot switch yet. It would make no sense as long as i2s audio is missing.
As soon as it is included, I will upgrade the C2 volumio image.
I have also problem with DSD.
I have Soekris DAM R2R Dac with Diyinhk xmos receiver.
No problems with Rpi2 and Moode/Ruune, No problems with Odroid C2 Rune.
It just doesn’t lock with either DSD Dierct or DoP shows 44,1 and lots of loud hissing.
No problem with all other material 24/192 plays fine.
I have the latest issue volumio.
I have Volumio Version volumio-2.395-2018-04-22 running and using it in combination with a RME ADI 2 DAC.
Unfortunately, I hear regular clicks during playback. After rebooting the clicks seem to disappear, but one can hear scratches now…
Is there a workaround or solution for this problem? I read some older postings about switching CPU etc. but this does not really work for me.
Thanks!
Not really,
The cpu affinity has been taken care of in the C1/C2 images and have shown to work in a number of cases.
USB Audio seems to be a pita for a number of DAC manufacturers, especially when it comes to RPI and in this case, also the Odroid C2.
With the RPi and its known usb issues, the RME ADI 2 DAC seems not to work very well, but I have no idea why the Odroid C2 misbehaves as well.
The cause could be bad implementation of standards, lacking expertise I have to assume RME did it right.
Bad usb drivers or usb drivers missing critical updates can cause problems too.
The 4.17.x kernel supports the C2 and has up-to-date usb drivers, raising hope.
Right now it makes no sense yet to build with mainline until Baylibre, on assignment by Amlogic to bring SoC sound support, is also finished with it.
Perhaps others have similar issues? I might reconsider a dev version in case I get multiple requests (> 5)
Hi gkkpch,
thanks for the quick reply and clear words. Too bad seeing the potential of odroid C2 unutilised, but I am no coder… Since, I’m looking forward to new versions for C2 and will check the corresponding threads from time to time.
I have noticed, Hardkernel now more or less officially moved to kernel version 3.16 for the C2.
Without giving you too much hope, I will give it a try and build a version with that kernel.
Being quite busy, don’t expect a reply within the next few days, could be a week or two.
And doing this, still gives no guarantee that it changes anything towards usb audio…
In the meanwhile I tried Libreelec, but it has the same issues. Further, I tried Archphile and it works like a charm.
I’m not sure, what this means for Volumio development, but maybe this information is helpful.
However, I’m looking forward to your new release, since I like the Volumio GUI and support of TFTs.
Cheers
Archphile for Odroid C2 has various optimizations. They are listed in the manual (http://archphile.org/manual/archphile-manual.pdf) (page 19)
