Hello
I noticed a small bug in the new Volumio GUI V3. It’s not tragic, but maybe you can eliminate it with one of the next releases.
When music is playing, the progress bar will scroll down the middle. If the time is in the range e.g. is the skip key, this is partially covered and therefore can not be used. So you can not choose the next piece of music in this situation.
See photo
Maybe you can improve that.
regards
rost21A
