Just tested on a fresh 3.054 image, it works like a charm with BassFly!
It is definitely a huge step forward:
- no problems with updates anymore
- it should with all sources, including Spotify (not tested yet, it will be the next step)
yes, his version
Thanks! I wonder what Iām doing wrong thenā¦
In fact, you have nothing to do special. On a fresh Volumio buster, just install your plugin (the version I modified). Configure your oled. Thatās it.
what DAC are you using?
Yeah, thatās exactly what I did. Very strange.
Just a pi3, no DACā¦
this is not working . Astephy said something to add this code if it is not working in an above posts:
the volumio is seen in Spotify app on my phone
DSD Files in buster beta v 3.054
I want to play some dsd files over my nas server but on mu dac it is shown 705.6pcm. When used to work it shows 5.64 DSD . MIxer is set to HW. DSD direct mode enabled. What options do i need to set in order to see DSD on my DAC
mpd oled and pepy plugins disabled.
Version of Spotify and Spotify connect from my repo are ready for thatā¦
But it is nt working
I see volumio in my phone app but is not conencted. Pls see the logs
Spotify_Connect_err.txt (9.7 KB)
I use it⦠But, in your case, thereās a problem with the volume mixer. So, needs some adjustments
You are refering to dsd files? Or spotify connect?
Spotify connect. Do you use the plugin from the branch alsa modular in my repo?
Yes, from modular alsa branch
fixed : by :
:Volumio version 2.779 (Released: Jun 8 18:35:15 CEST 2020) has reversed functions names for āDSD playback modeā: āDSD directā and āDSD over PCM (DoP)ā. Personally, I donāt mind, but it can be confusing for other Volumio users.ā old thread*
I guess it should be fixed in beta buster version .
Spectrum from mpd oled and meter are not working with DSD files . .
Dop is set because DSD direct and DOP namings are inversed , HW mixer is set
Not sure we can do something for that. Both plugins need PCM to work⦠But I may be wrong
I can confirm the plugin modified by @balbuze works fine with all the source Iāve tested
