ok thanks, I will try that for GPIO_buttons plug in.
And will deal with mpd_oled another way.
RPi 3B running Volumiobuster 3.066
Hifiberry AMP2
wifi from NAS
Iām controlling Volumio with Websocket API from Python using Python socketio library
When playing a track emitting Pause then Play causes the track to start from the beginning again not from where it left off. This is different behaviour from the browser UI which operates as expected. (Note I also saw the same issue with previous install 2.873, websocet API retstarts the track, browser UI starts where it left off)
I ran a simple Python script which did the following sequence:
Emit Play
Wait 20 seconds
Emit Pause
Wait 20 seconds
Emit Play
Logfile is here:
http://logs.volumio.org/volumiobuster/p9et1V3.html
Unrelated issue - mpd logfile contains
exception: Failed to open mixer for āalsaā: no such mixer control: PCM
Hi ,
I want to install the 80s80s radio plugin on buster version . Could you please point me out how to compile it to make it available also on buster version .User @Fybrox provided a fix for the index.js file - due to crashing Volumio 2.x.
You shouldnāt have to compile it - just install it the way you installed all the other plugins you have running currently. It should workā¦
Many thanks @fybrox , @ashthespy .
The plugin is working also on buster version with the fix from Fybrox.
This is just great , also album art is ok
Perhaps it could add it again in the pluginstore
@Fybrox. Do you encounter issue on volumio 2? On volumio 3.0 the ui from phone becomes stuck and I can longer control volumio. After I stopp the music from locally connect2 display the is ok. I can start another radio stationā¦
This is sporadic.
Edit
When I do volumio status I have observed that after seek keyword a vey long number string. I guess do to this the ui becomes stuck.
When I check this keyword on another radio station the string is composed from 4 or 5 numbers. Somehow in the plugin this string increases very much
Edit 2.
I have started to listen ghe 80s80s Radio From the plugin and the āseekā := 54566 string contained only 5 numbers, but as soon as I have started to play with ui from phone value if the string started to increase⦠Seek:= 6578ā¦n. And the ui becomes again stuck.
I realy live this plugin because all 80s and 90s are in a common place and the most important is the albumart for every song.
I really appreciate nay help. If I need to do something just pls telll me.
Hello !
Yes, I also noticed some bugs under Volumio 2.x :
A serious one when server for metadata answers busy or unavailable, it crashes Volumio.
Another less serious, not blocking I believe, that you notice and I also, in the state of Volumio, in connection with timer settings for songs.
I can watch but Iām running out of time to go fast. Iāll keep you posted here.
This thread is related to Volumio buster beta, aka Volumio 3. So create an other thread, and indicate your hw, the version for Volumio and all plugin you have installed. Thanks
Hello balbuze,
This plugin is installed on volumio buster beta c 3.067. I look in the future :).
I have installed mpd oled, peppymeter, touch plugin. All is working nice. As I said this 80s plugin is state of the art. If you cĆ¢nd make it work it will be a great pleasure for me and for others I guess. I can help with logsā¦
Regards
Yes I understand, Iāll post here itās better too I think:
Hi Folks,
Is anyone working on the Rotary Plugin for Volumio 3 ?
I noticed i could use the volume control with Hifiberry Digi as of the latest beta release āVolumiobuster-3.067-2021-04-16-piā
I tried to install the Plugin of Saiyato, but as expected it failed to install on the beta.
Any news regarding the 80s80s plugin.
Thanks for your help.
Nope sorry, I donāt use itā¦
It is a great plugin
give it a try pls
Hi!
Some new about Parameq4Volumio !
Attenuation (gain) is set automatically regarding value in PEQ
Additionnal attenuation can be set for each channel.
Now, unlimited number of PEQ! (even if I set a limit to 50 ;-))
Each PEQ can be set to affect Left channel, Right channel or both.
Why 50? Because the plugin can import file from REW and REW export is 20 PEQ max.
So for 2 channels imported, 40 PEQ max.
Format for PEQ in imported file is
Header, whatever it is...
Filter 1: ON PK Fc 58.70 Hz Gain -4.10 dB Q 5.014
Filter 2: ON PK Fc 136.5 Hz Gain -7.00 dB Q 3.115
Filter 3: ON PK Fc 192.0 Hz Gain -6.80 dB Q 2.285
Filter 4: ON PK Fc 197.5 Hz Gain 4.30 dB Q 4.874
Filter 5: ON PK Fc 264.0 Hz Gain 6.00 dB Q 1.786
Filter 6: ON PK Fc 320.0 Hz Gain -4.30 dB Q 4.730
Filter 7: ON PK Fc 667.0 Hz Gain 1.70 dB Q 7.289
Filter 8: ON PK Fc 940.0 Hz Gain -2.80 dB Q 1.994
Filter 9: ON PK Fc 1187 Hz Gain -2.70 dB Q 4.242
Filter 10: ON PK Fc 1764 Hz Gain -0.30 dB Q 6.002
Filter 11: ON PK Fc 1993 Hz Gain -2.70 dB Q 3.659
The plugin can also import Headphone profil from AutoEQ. Just choose the profil you want over 3800 in the scrolling list.
Feel free to test and feedback
Tried this after trouble with Brutefir and Volumio2.
It worked up to a point. I was using 2 sweep wav files, playing through the filters in Volumio, capturing with measurement software, all working. Adjust some filters, sweep again, repeat. Then when I added the last couple of filters, I suddenly get error message āFailed to open audio output.ā
Tried removing filters, disabling plugin, reboot, disabling dac, reboot, enable again, reboot etc etc⦠still not working. Any ideas?
May 15 11:23:11 volumio systemd[1350]: **Failed to start Music Player Daemon.**
May 15 11:23:11 volumio systemd[1350]: **mpd.service: Failed with result 'exit-code'.**
May 15 11:23:11 volumio systemd[1350]: **mpd.service: Main process exited, code=exited, status=1/FAILURE**
May 15 11:23:11 volumio mpd[1362]: May 15 11:23 : exception: nested: Failed to bind socket: Address already in use
May 15 11:23:11 volumio mpd[1362]: May 15 11:23 : exception: Failed to bind to '[::]:6600'
May 15 11:23:11 volumio systemd[1350]: Starting Music Player Daemon...
May 15 11:23:11 volumio systemd[1]: Started Session 1 of user volumio.
May 15 11:23:11 volumio systemd[1]: Started User Manager for UID 1000.
May 15 11:23:11 volumio systemd[1350]: Reached target Basic System.
May 15 11:23:11 volumio systemd[1350]: Reached target Sockets.
May 15 11:23:11 volumio systemd[1350]: Listening on D-Bus User Message Bus Socket.
May 15 11:23:11 volumio systemd[1350]: Listening on Sound System.
May 15 11:23:11 volumio systemd[1350]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 15 11:23:11 volumio systemd[1350]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
May 15 11:23:11 volumio systemd[1350]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
May 15 11:23:11 volumio systemd[1350]: Reached target Paths.
May 15 11:23:11 volumio systemd[1350]: Starting D-Bus User Message Bus Socket.
May 15 11:23:11 volumio systemd[1350]: Reached target Timers.
May 15 11:23:11 volumio systemd[1350]: **Failed to listen on mpd.socket.**
May 15 11:23:11 volumio systemd[1350]: **mpd.socket: Failed with result 'resources'.**
May 15 11:23:11 volumio systemd[1350]: **mpd.socket: Failed to listen on sockets: Address already in use**
May 15 11:23:11 volumio systemd[1350]: **mpd.socket: Failed to create listening socket ([::]:6600): Address already in use**
I may have been able to solve and replicate this problem.
First I reinstalled the plugin completely.
Then, it seems like this error occurs if you use L, R, AND L+R filters. The error occured when I added a L+R. Removed it, only leaving separate L and R filters, and after some time it started working again. I also verified that it is not the number of total filters that breaks it. It is the adding of L+R.
Have not tried using only L+R.
What is the version of the plugin?
What is the version of Volumio?
Do you have/use a Myvolumio account?
You donāt need to remove/reinstall the plugin. This is not Windows
The problem comes from Mpd hanging due to a script (not related to the plugin).
It restart after near 90seconds⦠It is what you saw.
Volumio 3.073 is more stable on that point.
Plugin 0.2.7
Volumio 3.073
Myvolumio Yes
Iām not sure this is the issue. I tried enabling a L+R again, and it stops working. I waited more than 5 mins, still not working. Remove the L+R, and it works again.
