I’ve been enjoying my Volumio player for several months now, and I couldn’t be happier. However, a week ago, and all of sudden, my Volumio player will not connect to the WiFi anymore, the Ethernet connection work’s fine, but no WiFi. I pulled the Volumio SD card and replaced it with a Raspian, and it connects right away, so its not the Raspi. I tried a new SD card with a fresh Volumio download and it still will not connect. I have 2 Raspberry Pi’s and it doesn’t work on either board. All of the settings on the Volumio are at default and running the latest update. Also, when I ran the set-up Wizard, it said that the wireless connection failed, and BTW, my Raspi is within 3 feet of the router and all of my other wireless devices work just fine so.
Have you already tried to simply re-configure the wifi in Volumio? From the logs it seems that it cannot authenticate due to a wrong key - see the code snippet below that pops up several times in your log. As far I can see - but I’m no expert - there is nothing strange going on in the logs.
Try resetting the wifi in Volumio first, maybe also reboot the router (in some cases that also helps), and please report back
Oct 14 16:15:01 volumio wpa_supplicant[828]: wlan0: CTRL-EVENT-SSID-REENABLED id=1 ssid="Frontier0104"
Oct 14 16:15:01 volumio wpa_supplicant[828]: wlan0: Trying to associate with SSID 'Frontier0104'
Oct 14 16:15:04 volumio wpa_supplicant[828]: wlan0: Associated with 74:44:01:28:c5:87
Oct 14 16:15:04 volumio wpa_supplicant[828]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
Oct 14 16:15:14 volumio wpa_supplicant[828]: wlan0: Authentication with 74:44:01:28:c5:87 timed out.
Oct 14 16:15:14 volumio wpa_supplicant[828]: wlan0: CTRL-EVENT-DISCONNECTED bssid=74:44:01:28:c5:87 reason=3 locally_generated=1
Oct 14 16:15:14 volumio wpa_supplicant[828]: wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Oct 14 16:15:14 volumio wpa_supplicant[828]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=1 ssid="Frontier0104" auth_failures=10 duration=139 reason=WRONG_KEY
Hello PaulM and thank you for supplying that snippet of my log file.
For the most part, I don’t understand log files but what got my attention was on the very last line where it stated “reason=WRONG_KEY”, so I thought I’d take a look, and sure enough, it “was” the wrong key!
Clearly at some point in time I put that wrong key in, but I don’t know why I would have had to since it has been working just fine. Hmm but I’ll take the blame on this one
Thanks again Paul for helping me narrow down the possibilities because now I have a working “wireless” Volumio player once again.
I have had the same problem with many versions of Volumio released in 2020.
Every time I reflash the micro-SD card with the latest version of Volumio and get going again.
Yesterday it happenend again with version 2.853, and yet again I am reflashing the micro-SD card.
