I have a setup running Raspyfi 1.0 successfully. I have been trying to upgrade to Volumio 1.1 and 1.2. In either case, the download checksums match; the image is written successfully; but the Pi never boots up.
The Pi has all its lights on, but there’s no display through HDMI nor is the web interface accessible. I can’t even SSH into the system as it doesn’t acquire an IP through DHCP.
I have tried different SD cards as well; including ones that work fine with Raspyfi.
Could also be your sd card reader slot on the pi is broken, its a very common problem and sometimes hard to determine (I have the same problem, solved it with a clothespin:-)
