Volumio has gotten more stable, but there are still times where I get myself back into a corner that only a reset will fix. This is a roadblock to being able store my music files on the same card as Volumio. If I have to reset Volumio then I will have to also spend hours copying 200+ gig of music files again. Is there a way to provide a reset option that will reset everything, but not remove my music files that are stored on the SD card?
No, sorry…
