Node-Red API
Hello
i want to send a command to volumio.
I do not know how I need to configure
can i use websocket or http request?
How do I describe the commands?
i dont’ find any exampel.
It possible to send UDP command to Volumio?
Best regards
hi,
have you had a look here : https://volumio.github.io/docs/ ?
Yes but i dont find any information for my problem
Gesendet von meinem SM-G930F mit Tapatalk
Would like to know how to get this to work with websocket nodes in Node-Red. The API documentation doesn’t help as much of that (connectivity) is under the covers in Node Red.
