I just switched from Volumio1.5Cuboxi.img to volumio-2.029-2016-11-18-cuboxi.img .
Wlan worked within 1.5.
With Volumio2 eth0 works , but there no wlan interface .
But wireless.services are not started:
[code]root@volumio:~# systemctl status -l wireless.service
● wireless.service - Wireless Services
Loaded: loaded (/lib/systemd/system/wireless.service; enabled)
Active: failed (Result: exit-code) since Fri 2016-11-18 13:00:21 UTC; 1 weeks 1 days ago
Process: 733 ExecStart=/volumio/app/plugins/system_controller/network/wireless.js start (code=exited, status=1/FAILURE)
Nov 18 13:00:21 volumio wireless.js[733]: at /volumio/app/plugins/system_controller/network/wireless.js:175:16
Nov 18 13:00:21 volumio wireless.js[733]: at /volumio/node_modules/wireless-tools/iwconfig.js:129:16
Nov 18 13:00:21 volumio wireless.js[733]: at ChildProcess.exithandler (child_process.js:213:5)
Nov 18 13:00:21 volumio wireless.js[733]: at emitTwo (events.js:106:13)
Nov 18 13:00:21 volumio wireless.js[733]: at ChildProcess.emit (events.js:191:7)
Nov 18 13:00:21 volumio wireless.js[733]: at maybeClose (internal/child_process.js:877:16)
Nov 18 13:00:21 volumio wireless.js[733]: at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
Nov 18 13:00:21 volumio systemd[1]: wireless.service: control process exited, code=exited status=1
Nov 18 13:00:21 volumio systemd[1]: Failed to start Wireless Services.
[/code]
root@volumio:~# uname -a
Linux volumio 4.7.2 #13 SMP Mon Sep 26 10:50:12 CEST 2016 armv7l GNU/Linux
root@volumio:~# lsmod
Module Size Used by
nfsd 281319 2
nfs_acl 2925 1 nfsd
xt_REDIRECT 1286 1
nf_nat_redirect 3057 1 xt_REDIRECT
iptable_nat 1766 1
nf_conntrack_ipv4 15524 1
nf_defrag_ipv4 1620 1 nf_conntrack_ipv4
nf_nat_ipv4 5476 1 iptable_nat
nf_nat 17646 2 nf_nat_redirect,nf_nat_ipv4
nf_conntrack 144992 3 nf_nat,nf_nat_ipv4,nf_conntrack_ipv4
ip_tables 12862 1 iptable_nat
brcmfmac 187380 0
brcmutil 8562 1 brcmfmac
dw_hdmi_ahb_audio 4082 0
evbug 2004 0
squashfs 31268 1
overlay 30534 1
As firmware is installed
root@volumio:~# aptitude search "firmware-brcm*"
i firmware-brcm80211
with these files:
root@volumio:~# ls -1 /lib/firmware/brcm/
bcm43xx-0.fw
bcm43xx_hdr-0.fw
brcmfmac43143-sdio.bin
brcmfmac43241b0-sdio.bin
brcmfmac43241b4-sdio.bin
brcmfmac4329-sdio.bin
brcmfmac4330-sdio.bin
brcmfmac4334-sdio.bin
brcmfmac4335-sdio.bin
brcmfmac43362-sdio.bin
brcmfmac4354-sdio.bin
root@volumio:~# ifconfig
eth0 Link encap:Ethernet HWaddr d0:63:b4:00:c4:0f
inet addr:192.168.1.100 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:23195 errors:0 dropped:0 overruns:0 frame:0
TX packets:10378 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:29406606 (28.0 MiB) TX bytes:1721142 (1.6 MiB)
ip6tnl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING NOARP MTU:1452 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:1 dropped:1 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:6032 errors:0 dropped:0 overruns:0 frame:0
TX packets:6032 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:549502 (536.6 KiB) TX bytes:549502 (536.6 KiB)
sit0 Link encap:IPv6-in-IPv4
UP RUNNING NOARP MTU:1480 Metric:1
TX packets:0 errors:1 dropped:0 overruns:1 carrier:0
From dmesg
8.847598] evbug: Connected device: input1 (MCE IR Keyboard/Mouse (gpio-rc-recv) at /input0)
[ 8.847614] evbug: Connected device: input2 (Dell Dell QuietKey Keyboard at usb-ci_hdrc.0-1/input0)
[ 8.847659] evbug: Connected device: input3 (gpio-keys at gpio-keys/input0)
[ 9.592274] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4330-sdio.txt failed with error -2
[ 10.569356] systemd-journald[262]: Received request to flush runtime journal from PID 1
[ 10.757930] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 10.853365] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.893096] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 11.777571] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 12.028951] Atheros 8035 ethernet 2188000.ethernet:00: attached PHY driver [Atheros 8035 ethernet] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
[ 16.059746] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 24.189769] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Any idea what could be wrong and how I can fix it ?
Any hints are apreciated .
