No Web Volumio Server listening?
Hello, I just installed Volumio on a Raspberry Pi. The installation went fine, no errors.
When I boot, and view the console of the Raspberry Pi, I see a “Volumio” splash screen briefly. Then, I get a textual login screen:
volumio login:
Even though I was initially expecting a graphical screen, I read that what I am seeing is normal. The Raspberry Pi is getting an IP address from my ethernet connection, but when I try to point a web browser at it I see nothing. I learned that I should be able to log into the device using ‘volumio’ and ‘volumio’ as password. I did this at that console screen and logged in. I then did a ‘ps -ef’ to see what processes were running. There were quite a few, but no web/http server. I did a ‘netstat -an|grep LISTEN’ to find what ports were listening, and 80/tcp was not listed (nor was 443). I did a sudo to become root, and started sshd so I could connect remotely. Here’s what I see from ‘ps -ef’:
volumio@volumio:~$ ps -ef
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  3 21:01 ?        00:00:04 /sbin/init
root         2     0  0 21:01 ?        00:00:00 [kthreadd]
root         3     2  0 21:01 ?        00:00:00 [kworker/0:0]
root         4     2  0 21:01 ?        00:00:00 [kworker/0:0H]
root         5     2  0 21:01 ?        00:00:00 [kworker/u8:0]
root         6     2  0 21:01 ?        00:00:00 [mm_percpu_wq]
root         7     2  0 21:01 ?        00:00:00 [ksoftirqd/0]
root         8     2  0 21:01 ?        00:00:00 [rcu_sched]
root         9     2  0 21:01 ?        00:00:00 [rcu_bh]
root        10     2  0 21:01 ?        00:00:00 [migration/0]
root        11     2  0 21:01 ?        00:00:00 [cpuhp/0]
root        12     2  0 21:01 ?        00:00:00 [cpuhp/1]
root        13     2  0 21:01 ?        00:00:00 [migration/1]
root        14     2  0 21:01 ?        00:00:00 [ksoftirqd/1]
root        15     2  0 21:01 ?        00:00:00 [kworker/1:0]
root        16     2  0 21:01 ?        00:00:00 [kworker/1:0H]
root        17     2  0 21:01 ?        00:00:00 [cpuhp/2]
root        18     2  0 21:01 ?        00:00:00 [migration/2]
root        19     2  0 21:01 ?        00:00:00 [ksoftirqd/2]
root        20     2  0 21:01 ?        00:00:00 [kworker/2:0]
root        21     2  0 21:01 ?        00:00:00 [kworker/2:0H]
root        22     2  0 21:01 ?        00:00:00 [cpuhp/3]
root        23     2  0 21:01 ?        00:00:00 [migration/3]
root        24     2  0 21:01 ?        00:00:00 [ksoftirqd/3]
root        25     2  0 21:01 ?        00:00:00 [kworker/3:0]
root        26     2  0 21:01 ?        00:00:00 [kworker/3:0H]
root        27     2  0 21:01 ?        00:00:00 [kdevtmpfs]
root        28     2  0 21:01 ?        00:00:00 [netns]
root        29     2  0 21:01 ?        00:00:00 [kworker/0:1]
root        30     2  0 21:01 ?        00:00:00 [kworker/1:1]
root        31     2  0 21:01 ?        00:00:00 [kworker/2:1]
root        32     2  0 21:01 ?        00:00:00 [kworker/3:1]
root        33     2  0 21:01 ?        00:00:00 [khungtaskd]
root        34     2  0 21:01 ?        00:00:00 [oom_reaper]
root        35     2  0 21:01 ?        00:00:00 [writeback]
root        36     2  0 21:01 ?        00:00:00 [kcompactd0]
root        37     2  0 21:01 ?        00:00:00 [crypto]
root        38     2  0 21:01 ?        00:00:00 [kblockd]
root        39     2  0 21:01 ?        00:00:00 [watchdogd]
root        40     2  0 21:01 ?        00:00:00 [rpciod]
root        41     2  0 21:01 ?        00:00:00 [xprtiod]
root        42     2  0 21:01 ?        00:00:00 [kworker/u8:1]
root        44     2  0 21:01 ?        00:00:00 [kswapd0]
root        45     2  0 21:01 ?        00:00:00 [nfsiod]
root        55     2  0 21:01 ?        00:00:00 [kthrotld]
root        56     2  0 21:01 ?        00:00:00 [iscsi_eh]
root        57     2  0 21:01 ?        00:00:00 [dwc_otg]
root        58     2  0 21:01 ?        00:00:00 [DWC Notificatio]
root        59     2  0 21:01 ?        00:00:00 [kworker/0:2]
root        60     2  0 21:01 ?        00:00:00 [vchiq-slot/0]
root        61     2  0 21:01 ?        00:00:00 [vchiq-recy/0]
root        62     2  0 21:01 ?        00:00:00 [vchiq-sync/0]
root        63     2  0 21:01 ?        00:00:00 [vchiq-keep/0]
root        64     2  0 21:01 ?        00:00:00 [SMIO]
root        65     2  0 21:01 ?        00:00:00 [irq/92-mmc1]
root        66     2  0 21:01 ?        00:00:00 [kworker/0:3]
root        67     2  0 21:01 ?        00:00:00 [kworker/0:4]
root        75     2  0 21:01 ?        00:00:00 [mmcqd/0]
root        98     2  0 21:01 ?        00:00:00 [jbd2/mmcblk0p2-]
root        99     2  0 21:01 ?        00:00:00 [ext4-rsv-conver]
root       106     2  0 21:01 ?        00:00:00 [loop0]
root       109     2  0 21:01 ?        00:00:00 [kworker/3:1H]
root       113     2  0 21:01 ?        00:00:00 [kworker/2:1H]
root       127     2  0 21:01 ?        00:00:00 [jbd2/mmcblk0p3-]
root       128     2  0 21:01 ?        00:00:00 [ext4-rsv-conver]
root       135     2  0 21:01 ?        00:00:00 [kworker/1:1H]
root       136     2  0 21:01 ?        00:00:00 [ipv6_addrconf]
root       142     2  0 21:01 ?        00:00:00 [kworker/0:1H]
root       165     1  0 21:01 ?        00:00:01 /lib/systemd/systemd-journald
root       168     2  0 21:01 ?        00:00:00 [kworker/1:2]
root       174     2  0 21:01 ?        00:00:00 [kworker/u8:2]
root       178     2  0 21:01 ?        00:00:00 [kworker/0:5]
root       179     2  0 21:01 ?        00:00:00 [kworker/2:2]
root       190     1  0 21:01 ?        00:00:00 /lib/systemd/systemd-udevd
root       302     2  0 21:01 ?        00:00:00 [cfg80211]
root       307     2  0 21:01 ?        00:00:00 [brcmf_wq/mmc1:0]
root       308     2  0 21:01 ?        00:00:00 [brcmf_wdog/mmc1]
root       330     2  0 21:01 ?        00:00:00 [kworker/u8:3]
root       414     2  0 21:01 ?        00:00:00 [kworker/2:3]
root       475     1  0 21:01 ?        00:00:00 dhcpcd eth0
root       532     1  1 21:01 ?        00:00:01 /usr/sbin/haveged --Foreground -
volumio    536     1  0 21:01 ?        00:00:00 /usr/bin/udisks-glue --foregroun
volumio    540     1  0 21:01 ?        00:00:00 /usr/local/bin/volumio-remote-up
root       547     1  0 21:01 ?        00:00:00 /lib/systemd/systemd-logind
avahi      550     1  0 21:01 ?        00:00:00 avahi-daemon: running [volumio.l
message+   552     1  0 21:01 ?        00:00:00 /usr/bin/dbus-daemon --system --
root       555     1  0 21:01 ?        00:00:00 /sbin/dhcpcd -q -b
avahi      627   550  0 21:01 ?        00:00:00 avahi-daemon: chroot helper
root       686     1  0 21:01 ?        00:00:00 /usr/lib/udisks/udisks-daemon --
mpd        689     1  0 21:01 ?        00:00:01 /usr/bin/mpd --no-daemon
root       748   686  0 21:01 ?        00:00:00 udisks-daemon: not polling any d
root       756     1  0 21:01 ?        00:00:00 /usr/sbin/ifplugd -i eth0 -q -f
root       760     1  0 21:01 tty1     00:00:00 /bin/login --
root       762     1  0 21:01 ?        00:00:00 /sbin/rpcbind -w
ntp        774     1  0 21:01 ?        00:00:00 /usr/sbin/ntpd -p /var/run/ntpd.
root       780     1  0 21:01 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
root       785     2  0 21:01 ?        00:00:00 [kworker/3:2]
root       874     1  0 21:01 ?        00:00:00 /usr/sbin/winbindd
root       875     1  0 21:01 ?        00:00:00 /bin/bash /bin/hotspot.sh start
root       878     1  0 21:01 ?        00:00:00 /usr/sbin/nmbd -D
root       879   878  0 21:01 ?        00:00:00 /usr/sbin/nmbd -D
volumio    887     1  8 21:01 ?        00:00:10 /usr/local/bin/node /volumio/ind
root       895   874  0 21:01 ?        00:00:00 /usr/sbin/winbindd
nobody     897     1  0 21:01 ?        00:00:00 /usr/sbin/dnsmasq --address=/#/1
root       905     1  0 21:01 ?        00:00:00 /usr/sbin/dhcpd
root       908     1  0 21:01 ?        00:00:00 /usr/sbin/smbd -D
root       917   874  0 21:01 ?        00:00:00 /usr/sbin/winbindd
root       920   875  0 21:01 ?        00:00:00 /usr/sbin/hostapd /etc/hostapd/h
root       921   874  0 21:01 ?        00:00:00 /usr/sbin/winbindd
root       922   908  0 21:01 ?        00:00:00 /usr/sbin/smbd -D
volumio    943     1  0 21:01 ?        00:00:00 /lib/systemd/systemd --user
volumio    947   943  0 21:01 ?        00:00:00 (sd-pam)
volumio    952   760  0 21:01 tty1     00:00:00 -bash
volumio    961   887  0 21:01 ?        00:00:00 /bin/node /volumio/app/plugins/m
volumio    967   961  1 21:01 ?        00:00:01 /bin/node /volumio/app/plugins/m
volumio    968   961  1 21:01 ?        00:00:01 /bin/node /volumio/app/plugins/m
volumio    973   961  1 21:01 ?        00:00:01 /bin/node /volumio/app/plugins/m
volumio    994     1  0 21:01 ?        00:00:00 /bin/streaming-daemon
volumio   1042     1  0 21:01 ?        00:00:00 /usr/local/bin/shairport-sync
volumio   1095     1  0 21:01 ?        00:00:00 /usr/bin/upmpdcli -c /tmp/upmpdc
root      1122   952  0 21:01 tty1     00:00:00 sudo su -
root      1149  1122  0 21:01 tty1     00:00:00 su -
root      1154  1149  0 21:01 tty1     00:00:00 -su
root      1201     1  0 21:01 ?        00:00:00 /usr/sbin/sshd -D
root      1632  1201  0 21:02 ?        00:00:00 sshd: volumio [priv]
volumio   1659  1632  0 21:02 ?        00:00:00 sshd: volumio@pts/0
volumio   1661  1659  0 21:02 pts/0    00:00:00 -bash
volumio   1954  1661  0 21:03 pts/0    00:00:00 ps -ef
volumio@volumio:~$
And what is listening (netstat -an|grep LISTEN):
volumio@volumio:~$ netstat -an |grep LISTEN
tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
tcp        0      0 10.0.0.214:49152        0.0.0.0:*               LISTEN
tcp6       0      0 :::7777                 :::*                    LISTEN
tcp6       0      0 :::6599                 :::*                    LISTEN
tcp6       0      0 :::5000                 :::*                    LISTEN
tcp6       0      0 :::6600                 :::*                    LISTEN
tcp6       0      0 :::139                  :::*                    LISTEN
tcp6       0      0 :::111                  :::*                    LISTEN
tcp6       0      0 :::53                   :::*                    LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
tcp6       0      0 :::3000                 :::*                    LISTEN
tcp6       0      0 :::3001                 :::*                    LISTEN
tcp6       0      0 :::3005                 :::*                    LISTEN
tcp6       0      0 :::445                  :::*                    LISTEN
tcp6       0      0 :::49152                :::*                    LISTEN
unix  2      [ ACC ]     STREAM     LISTENING     11792    /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING     11794    /run/mpd/socket
unix  2      [ ACC ]     STREAM     LISTENING     11797    /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     12595    /var/run/dhcpcd.sock
unix  2      [ ACC ]     STREAM     LISTENING     12597    /var/run/dhcpcd.unpriv.sock
unix  2      [ ACC ]     STREAM     LISTENING     13622    /run/rpcbind.sock
unix  2      [ ACC ]     STREAM     LISTENING     1490     /run/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     19670    /run/user/1000/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     16618    /var/run/samba/nmbd/unexpected
unix  2      [ ACC ]     SEQPACKET  LISTENING     1514     /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     1518     /run/systemd/journal/stdout
unix  2      [ ACC ]     STREAM     LISTENING     16634    /var/run/samba/winbindd/pipe
unix  2      [ ACC ]     STREAM     LISTENING     16637    /var/lib/samba/winbindd_privileged/pipe
volumio@volumio:~$
Anyone have any idea what might be wrong?
I tried going to the live chat thing/site, but nobody seems to be paying attention there.
Thanks!
It just started working, and I don’t see how. I’m able to connect to it with ip.of.the.pi … but there is still no 80/tcp listening.
Baffled!
But there’s no evidence of 80/tcp listening.
How is this possible?
Thanks!
The trafic is redirected to port 3000
Interesting, and confirmed. Why is it set up this way? And what is doing the redirecting?
Thanks for the update!
