Hi , I`m a new member. Today I was installed Volumio with my volumio - virtuozo but I can not see Tidal or Qobuz. Is it normal that after some times it will appear? Or I should install some plugin additionally?
Thanks in advance for help.
You will find the login fields into my music settings
