Hi All
I use the Volumio-gui on my standard debian install on a pogoplug. For some reason with the change from v1.4 to v1.5 and now also v1.55 my browse tab only show the files that resides in the root of my music directory. It doesn’t show any of the subdirs (which holds most og my music), but if I search for the music it is found. The new library tab works fine
Best regards
Termo
