You could just copy-paste text from putty into this post with within code tags (</>
If not, try hosting them elsewhere such as imgbox.com/
or imgur.com
and add links.
Here are the 4 commands:
(“amixer -c1 scontrols” gives an error.)
volumio@volumio:~$ aplay -l
card 0: atm7059link [atm7059_link], device 0: ATC2603C PCM atc2603c-dai-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: atm7059link [atm7059_link], device 1: HDMI PCM atm7059-hdmi-dai-1 []
Subdevices: 1/1
card 0: atm7059link [atm7059_link], device 2: SPDIF PCM atm7059-spdif-dai-2 []
Subdevices: 1/1
card 1: DAC [Brooklyn DAC], device 0: USB Audio [USB Audio]
Subdevices: 1/1
volumio@volumio:~$ amixer
Simple mixer control 'Mic0 Mode Mux',0
Capabilities: enum
Items: 'Differential' 'Single ended'
Item0: 'Differential'
Simple mixer control 'ADC0 Digital Gain control',0
Capabilities: volume volume-joined
Playback channels: Mono
Capture channels: Mono
Limits: 0 - 15
Mono: 0 [0%]
Simple mixer control 'ADC0 Mux',0
Capabilities: enum
Items: 'None' 'FM' 'MIC0' 'FM MIC0' 'PAOUT'
Item0: 'None'
Simple mixer control 'AMP1 Gain boost Range select',0
Limits: 0 - 7
Mono: 3 [43%]
Simple mixer control 'AOUT FL FR Mixer FL FR',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'AOUT FL FR Mixer FM',0
Simple mixer control 'AOUT FL FR Mixer MIC',0
Simple mixer control 'Adc0 Digital Gain',0
Limits: 0 - 15
Mono: 0 [0%]
Simple mixer control 'Adc0 Gain',0
Playback channels: Front Left - Front Right
Capture channels: Front Left - Front Right
Limits: 0 - 15
Front Left: 9 [60%]
Front Right: 9 [60%]
Simple mixer control 'DAC Digital FL FR',0
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'DAC FL FR PLAYBACK',0
Simple mixer control 'DAC FL Gain',0
Limits: 0 - 255
Mono: 181 [71%]
Simple mixer control 'DAC FR Gain',0
Limits: 0 - 255
Mono: 181 [71%]
Simple mixer control 'DAC PA',0
Capabilities: volume volume-joined pswitch pswitch-joined
Limits: 0 - 40
Mono: 40 [100%] Playback [on]
Simple mixer control 'DAC PA OUTPUT Stage',0
Mono: Playback [on]
Simple mixer control 'Dummy earphone detect method',0
Simple mixer control 'Dummy earphone gain',0
Limits: 0 - 255
Front Left: 190 [75%]
Front Right: 190 [75%]
Simple mixer control 'Dummy earphone volume',0
Limits: 0 - 40
Mono: 40 [100%]
Simple mixer control 'Dummy mic Gain',0
Limits: 0 - 15
Front Left: 15 [100%]
Front Right: 15 [100%]
Simple mixer control 'Dummy mic mode',0
Mono: Playback [on]
Simple mixer control 'Dummy mic num',0
Limits: 0 - 2
Mono: 1 [50%]
Simple mixer control 'Dummy speaker gain',0
Limits: 0 - 255
Front Left: 170 [67%]
Front Right: 170 [67%]
Simple mixer control 'Dummy speaker volume',0
Limits: 0 - 40
Mono: 40 [100%]
Simple mixer control 'External MIC Power Voltage',0
Limits: 0 - 3
Mono: 3 [100%]
Simple mixer control 'External Mic Power',0
Mono: Playback [on]
Simple mixer control 'Internal Mic Power',0
Simple mixer control 'PA Output Swing Mux',0
Capabilities: enum
Items: 'Vpp2.4' 'Vpp1.6'
Item0: 'Vpp1.6'
Simple mixer control 'audio output mode switch',0
Capabilities: enum
Items: 'i2s' 'hdmi' 'spdif'
Item0: 'i2s'
Simple mixer control 'speaker on off switch',0
volumio@volumio:~$
volumio@volumio:~$ amixer -c0 scontrols
volumio@volumio:~$ amixer -c1 scontrols
amixer: Mixer hw:1 load error: Broken pipe
hmm sorry, looks like this is indeed a hardware/driver issue for your DAC.
It registers the mixer, which is why Volumio tries to use it, but it isn’t really usable.
Thanks for the debugging and confirmation
