Same issue on update to 2.799 here are the logs
I tried the edit to mpd.conf suggested here, with reboot. no change.
http://logs.volumio.org/volumio/QJvqixW.html
and SSH outputs:
==================================aplay=================================
volumio@volumio-listening-room:~$ aplay -l
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 3/4
card 2: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0 [HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0]
Subdevices: 1/1
card 7: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 2/2
card 7: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 2/2
======================config.txt==========================================
volumio@volumio-listening-room://$ cat /boot/config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
include userconfig.txt
Volumio i2s setting below: do not alter
dtoverlay=hifiberry-dacplus
====================cmdline.txt===========================================
splash quiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=serial0,115200 kgdboc=serial0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=0 snd-bcm2835.enable_compat_alsa=0
============================dmesg===================================
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.118-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:26:42 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 64 MiB at 0x000000003a000000
[ 0.000000] On node 0 totalpages: 1024000
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 827392 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[ 0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1022272
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:63:B3:97 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash quiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyS0,115200 kgdboc=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=0 snd-bcm2835.enable_compat_alsa=0
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3957864K/4096000K available (8192K kernel code, 690K rwdata, 2420K rodata, 2048K init, 860K bss, 72600K reserved, 65536K cma-reserved, 3244032K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 691 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 861 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28928 entries in 85 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000018] Switching to timer-based delay loop, resolution 18ns
[ 0.000244] Console: colour dummy device 80x30
[ 0.000269] console [tty1] enabled
[ 0.000311] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.000328] pid_max: default: 32768 minimum: 301
[ 0.000597] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000615] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001427] CPU: Testing write buffer coherency: ok
[ 0.001835] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002474] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002629] rcu: Hierarchical SRCU implementation.
[ 0.003483] smp: Bringing up secondary CPUs …
[ 0.004281] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005198] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006062] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006180] smp: Brought up 1 node, 4 CPUs
[ 0.006192] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006202] CPU: All CPU(s) started in HYP mode.
[ 0.006210] CPU: Virtualization extensions available.
[ 0.006912] devtmpfs: initialized
[ 0.017706] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017920] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017940] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.020090] pinctrl core: initialized pinctrl subsystem
[ 0.020886] NET: Registered protocol family 16
[ 0.024128] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.025740] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.025751] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.025943] Serial: AMBA PL011 UART driver
[ 0.028933] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.050029] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-04-27 14:33, variant start
[ 0.060045] raspberrypi-firmware soc:firmware: Firmware hash is 3a8f1793b758d6fb7f375edaa260e069ecd34c88
[ 0.103037] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.106071] vgaarb: loaded
[ 0.106423] SCSI subsystem initialized
[ 0.106620] usbcore: registered new interface driver usbfs
[ 0.106671] usbcore: registered new interface driver hub
[ 0.106772] usbcore: registered new device driver usb
[ 0.108205] clocksource: Switched to clocksource arch_sys_counter
[ 0.185907] VFS: Disk quotas dquot_6.6.0
[ 0.185986] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.186128] FS-Cache: Loaded
[ 0.186314] CacheFiles: Loaded
[ 0.195668] NET: Registered protocol family 2
[ 0.196300] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.196325] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.196390] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.196460] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.196591] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.196617] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.196816] NET: Registered protocol family 1
[ 0.197349] RPC: Registered named UNIX socket transport module.
[ 0.197359] RPC: Registered udp transport module.
[ 0.197369] RPC: Registered tcp transport module.
[ 0.197378] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.197393] PCI: CLS 0 bytes, default 64
[ 0.197591] Trying to unpack rootfs image as initramfs…
[ 1.729955] Freeing initrd memory: 19464K
[ 1.738067] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 1.740234] Initialise system trusted keyrings
[ 1.740417] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.750575] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.751067] NFS: Registering the id_resolver key type
[ 1.751099] Key type id_resolver registered
[ 1.751109] Key type id_legacy registered
[ 1.751127] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.755676] Key type asymmetric registered
[ 1.755687] Asymmetric key parser ‘x509’ registered
[ 1.755798] bounce: pool size: 64 pages
[ 1.755846] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.756009] io scheduler noop registered (default)
[ 1.756020] io scheduler deadline registered
[ 1.756186] io scheduler cfq registered
[ 1.756196] io scheduler mq-deadline registered
[ 1.756206] io scheduler kyber registered
[ 1.806981] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 1.807001] brcm-pcie fd500000.pcie: could not get clock
[ 1.807063] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.807101] brcm-pcie fd500000.pcie: MEM 0x600000000…0x603ffffff -> 0xf8000000
[ 1.858239] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 1.858511] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.858527] pci_bus 0000:00: root bus resource [bus 00-01]
[ 1.858543] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 1.858593] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.858730] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.861509] PCI: bus0: Fast back to back transfers disabled
[ 1.861526] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.861691] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.861751] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.861920] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.864577] PCI: bus1: Fast back to back transfers disabled
[ 1.864593] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 1.864640] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.864660] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.864690] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.864707] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.864916] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.865093] pcieport 0000:00:00.0: Signaling PME with IRQ 52
[ 1.865251] pcieport 0000:00:00.0: AER enabled with IRQ 52
[ 1.865387] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.865868] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.876156] Console: switching to colour frame buffer device 80x30
[ 1.878107] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 640x480
[ 1.881806] iproc-rng200 fe104000.rng: hwrng registered
[ 1.882028] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.882537] vc-sm: Videocore shared memory driver
[ 1.882928] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.893169] brd: module loaded
[ 1.902762] loop: module loaded
[ 1.903497] Loading iSCSI transport class v2.0-870.
[ 1.905211] libphy: Fixed MDIO Bus: probed
[ 1.905624] bcmgenet fd580000.genet: failed to get enet clock
[ 1.905641] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 1.905658] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 1.905673] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 1.905696] bcmgenet: Skipping UMAC reset
[ 1.905929] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 1.918232] libphy: bcmgenet MII bus: probed
[ 1.963492] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 1.964396] usbcore: registered new interface driver r8152
[ 1.964460] usbcore: registered new interface driver lan78xx
[ 1.964513] usbcore: registered new interface driver smsc95xx
[ 1.964726] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.964776] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.967089] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 1.967264] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 53
[ 1.967873] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.967887] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.967899] usb usb1: Product: xHCI Host Controller
[ 1.967910] usb usb1: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 1.967922] usb usb1: SerialNumber: 0000:01:00.0
[ 1.968496] hub 1-0:1.0: USB hub found
[ 1.968547] hub 1-0:1.0: 1 port detected
[ 1.968949] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.968970] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.968989] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.969290] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.969303] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.969314] usb usb2: Product: xHCI Host Controller
[ 1.969325] usb usb2: Manufacturer: Linux 4.19.118-v7l+ xhci-hcd
[ 1.969336] usb usb2: SerialNumber: 0000:01:00.0
[ 1.969822] hub 2-0:1.0: USB hub found
[ 1.969873] hub 2-0:1.0: 4 ports detected
[ 1.970978] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.971166] dwc_otg: FIQ enabled
[ 1.971175] dwc_otg: NAK holdoff enabled
[ 1.971183] dwc_otg: FIQ split-transaction FSM enabled
[ 1.971195] Module dwc_common_port init
[ 1.971411] usbcore: registered new interface driver uas
[ 1.971503] usbcore: registered new interface driver usb-storage
[ 1.971691] mousedev: PS/2 mouse device common for all mice
[ 1.972838] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.974432] sdhci: Secure Digital Host Controller Interface driver
[ 1.974441] sdhci: Copyright© Pierre Ossman
[ 1.974838] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.975243] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.978543] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.978692] hidraw: raw HID events driver © Jiri Kosina
[ 1.978811] usbcore: registered new interface driver usbhid
[ 1.978820] usbhid: USB HID core driver
[ 1.979739] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 1.981513] [vc_sm_connected_init]: start
[ 1.990510] [vc_sm_connected_init]: end - returning 0
[ 1.991617] Initializing XFRM netlink socket
[ 1.991644] NET: Registered protocol family 17
[ 1.991751] Key type dns_resolver registered
[ 1.992262] Registering SWP/SWPB emulation handler
[ 1.992845] registered taskstats version 1
[ 1.992862] Loading compiled-in X.509 certificates
[ 1.999882] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.999947] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 2.005002] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.005550] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 2.006188] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.006199] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 2.031367] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[ 2.031445] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[ 2.047915] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.049662] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.051263] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.054137] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.055739] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.060901] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 2.063606] of_cfs_init
[ 2.063774] of_cfs_init: OK
[ 2.072324] Freeing unused kernel memory: 2048K
[ 2.072584] Run /init as init process
[ 2.106055] random: fast init done
[ 2.158686] mmc0: new ultra high speed DDR50 SDXC card at address 1234
[ 2.162154] mmcblk0: mmc0:1234 SA64G 58.0 GiB
[ 2.162683] mmc1: new high speed SDIO card at address 0001
[ 2.164417] mmcblk0: p1 p2 p3
[ 2.230534] initramfs: Booting Volumio for BCM2835
[ 2.230688] initramfs: This script mounts rootfs RO with an overlay RW layer.
[ 2.253261] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.272567] fuse init (API version 7.27)
[ 2.273991] initramfs: IMGPART=/dev/mmcblk0p2
[ 2.274123] initramfs: IMGFILE=/volumio_current.sqsh
[ 2.274330] initramfs: Boot delay (except first time) will be 5 seconds
[ 2.318097] initramfs: /dev/mmcblk0p2:
[ 2.338258] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.519660] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 2.519674] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.519687] usb 1-1: Product: USB2.0 Hub
[ 2.521616] hub 1-1:1.0: USB hub found
[ 2.521865] hub 1-1:1.0: 4 ports detected
[ 2.940643] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 2.969394] usb 2-2: New USB device found, idVendor=1058, idProduct=25f3, bcdDevice=10.12
[ 2.969408] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 2.969420] usb 2-2: Product: My Passport 25F3
[ 2.969433] usb 2-2: Manufacturer: Western Digital
[ 2.969444] usb 2-2: SerialNumber: 313934334850343032393438
[ 2.987658] scsi host0: uas
[ 2.989274] scsi 0:0:0:0: Direct-Access WD My Passport 25F3 1012 PQ: 0 ANSI: 6
[ 2.991031] sd 0:0:0:0: [sda] 1000148992 512-byte logical blocks: (512 GB/477 GiB)
[ 2.991045] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.991216] sd 0:0:0:0: [sda] Write Protect is off
[ 2.991231] sd 0:0:0:0: [sda] Mode Sense: 67 00 10 08
[ 2.991621] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, supports DPO and FUA
[ 2.991859] scsi 0:0:0:1: Enclosure WD SES Device 1012 PQ: 0 ANSI: 6
[ 2.992359] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 3.269025] sda: sda1 sda2
[ 3.271756] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 3.271907] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.536160] EXT4-fs (mmcblk0p2): recovery complete
[ 4.845650] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.847838] initramfs: Doing a 5 second delay here to give kernel load a headstart
[ 9.852052] initramfs: Checking for USB updates
[ 9.971096] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 18.201845] EXT4-fs (mmcblk0p3): recovery complete
[ 18.205270] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 18.209329] initramfs: With Option:
[ 18.370599] initramfs: VOLUMIO_VERSION=“2.799”
[ 18.370745] initramfs: Finish initramfs, continue booting Volumio
[ 18.771437] random: systemd: uninitialized urandom read (16 bytes read)
[ 18.777724] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 18.778038] systemd[1]: Detected architecture ‘arm’.
[ 18.897775] NET: Registered protocol family 10
[ 18.899086] Segment Routing with IPv6
[ 18.899283] systemd[1]: Inserted module ‘ipv6’
[ 18.901215] systemd[1]: Set hostname to .
[ 18.990902] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 19.068507] random: systemd: uninitialized urandom read (16 bytes read)
[ 19.143158] systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown lvalue ‘ProtectKernelTunables’ in section ‘Service’
[ 19.143208] systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue ‘ProtectControlGroups’ in section ‘Service’
[ 19.143253] systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue ‘ProtectKernelModules’ in section ‘Service’
[ 19.143308] systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown lvalue ‘RestrictNamespaces’ in section ‘Service’
[ 19.204672] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 19.207125] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 19.428005] i2c /dev entries driver
[ 19.464941] systemd-udevd[205]: starting version 215
[ 19.868019] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 19.877447] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 19.877969] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 19.879900] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 19.947684] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.950376] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 19.950392] [vc_sm_connected_init]: start
[ 19.962417] [vc_sm_connected_init]: installed successfully
[ 19.996922] media: Linux media interface: v0.10
[ 20.176081] videodev: Linux video capture interface: v2.00
[ 20.233936] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 20.269466] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 20.270524] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 20.289005] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 20.289051] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 20.292936] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 20.299194] snd_bcm2835: unknown parameter ‘index’ ignored
[ 20.301253] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 20.301289] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 20.304818] bcm2835_audio soc:audio: card created with 4 channels
[ 20.308987] bcm2835_audio soc:audio: card created with 4 channels
[ 20.309252] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 20.309281] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 20.469494] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 20.469712] scsi 0:0:0:1: Attached scsi generic sg1 type 13
[ 20.496665] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered - will retry
[ 20.505503] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 20.600536] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 20.627818] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 20.628974] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 20.628990] cfg80211: failed to load regulatory.db
[ 20.695265] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 20.714459] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 20.742400] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 20.746732] usbcore: registered new interface driver brcmfmac
[ 20.747280] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 20.873035] pcm512x 1-004d: Linked as a consumer to regulator.1
[ 21.005317] snd-rpi-hifiberry-dacplus soc:sound: pcm512x-hifi <-> fe203000.i2s mapping ok
[ 21.099897] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 21.152755] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 21.184412] systemd-journald[194]: Received request to flush runtime journal from PID 1
[ 22.412734] bcmgenet: Skipping UMAC reset
[ 22.518952] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 22.558308] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 23.267822] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 23.529404] bcmgenet fd580000.genet eth0: Link is Down
[ 23.701881] uart-pl011 fe201000.serial: no DMA platform data
[ 24.356775] Bluetooth: Core ver 2.22
[ 24.356841] NET: Registered protocol family 31
[ 24.356851] Bluetooth: HCI device and connection manager initialized
[ 24.356879] Bluetooth: HCI socket layer initialized
[ 24.356895] Bluetooth: L2CAP socket layer initialized
[ 24.356938] Bluetooth: SCO socket layer initialized
[ 24.470559] Bluetooth: HCI UART driver ver 2.3
[ 24.470574] Bluetooth: HCI UART protocol H4 registered
[ 24.470670] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 24.476746] Bluetooth: HCI UART protocol Broadcom registered
[ 25.524647] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.524653] Bluetooth: BNEP filters: protocol multicast
[ 25.524663] Bluetooth: BNEP socket layer initialized
[ 25.730181] random: crng init done
[ 25.730189] random: 7 urandom warning(s) missed due to ratelimiting
[ 25.827039] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 26.022903] hfsplus: Filesystem was not cleanly unmounted, running fsck.hfsplus is recommended. mounting read-only.
[ 28.794744] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
Please test it and report back
