same problem here: I use the RPI 7’ display on a RPI 3B+ and the Hifiberry DAC 2 HD and Volumio
and update to latest version 2.799. The Hifiberry is conflict with the RPI 7’ display and plugin version 1.1.8. The detail of the plugin notes: ‘Using this plugin is not recommended with Raspberry PI B+! Suggested, Raspberry PI 3, Odroid C1 or C2’. I have no problems with this setup and the Hifiberry Digi + pro board before the update to 2.799. When i disable the power to the display everything works. After the latest update this error ocured. Any solutions or experiences? kind regards
Log when display is disconnected:
aplay -l
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
card 2: sndrpihifiberry [snd_rpi_hifiberry_dacplushd], device 0: HiFiBerry DAC+ HD HiFi pcm179x-hifi-0 [HiFiBerry DAC+ HD HiFi pcm179x-hifi-0]
Subdevices: 0/1
Can you also post the log with the display connected?
I can’t, becaus after I tinkered around for a whole day yesterday I was frustrated and locked the screen away.
This is exactly the point, enabling DSI touchscreen makes HDMI to disappear from the list and I2S DAC becomes card1
I got it working. Its actually quite simple, it looks like the enumeration of output devices is not working.
Edit the /etc/mpd.conf file.
Find the audio output section
change the device “hw:1,0” - it was 2,0 before.
it worked for me.
with DSI touchscreen connected:
volumio@volumio-home:~$ aplay -l
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
Subdevices: 1/1
without DSI touchscreen
Subdevices: 4/4
Subdevices: 4/4
card 2: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
Subdevices: 1/1
Could you write it out step by step so we can all fix the problem
I will try. Enable SSH, by going to http:\your volumio IP\dev.
click enable under ssh.
then connect to the volumio via for example Bitvise SSH (i use this one)
there is a file manager with the program so its probably the best way, find the mpd.conf file under the \etc directory and double click on it to edit, remember to save.
or using the terminal, find the directory and sudo nano mpd.conf
I hope it hepls?
Works for me but no volume control possible. Mixer is set to ‘undefined’. Anything I am missing?
I have mine on none, so I cannot answer that. Another thing to remember, is that the change will be overwritten if you change your output device, so its necessary to edit the file again.
Thanks you. Since it’s reverting back to using the non-existent card2 after changing output, it really is a bug that might be fixed soon. I spent the whole day yesterday trying to figure this out, thinking I was just too unskilled.
Got mine working, thanks for the solution!
I can’t test myself ATM but maybe you can check if it helps to add
snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_compat_alsa=0
to /boot/cmdline.txt to get back all endpoints as different ALSA devices?
Edit: Possibly it is necessary to set snd_bcm2835.enable_compat_alsa=1 respectively to leave out snd_bcm2835.enable_compat_alsa completely if you should encounter problems choosing the default device.
Sure i’ll test right now
original cmdline.txt already had the option snd_bcm2835.enable_compat_alsa=0
with DSI touchscreen and snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd-bcm2835.enable_compat_alsa=0
Subdevices: 8/8
Subdevices: 1/1
with DSI touchscreen and snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd-bcm2835.enable_compat_alsa=1
Subdevices: 3/3
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 2/2
card 2: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 2/2
card 3: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
card 2: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 2/2
card 3: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 2/2
with DSI touchscreen and snd_bcm2835.enable_hdmi=1
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 1/1
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 1/1
with DSI touchscreen and all strings you suggested removed
Subdevices: 7/7
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 0/1
to summarize, the fix should be this:
- remove snd-bcm2835.enable_compat_alsa=0
- add snd_bcm2835.enable_headphones=1
with this change problem is gone, both with and without DSI touchscreen connected.
I performed this test with a RPi4 (2Gb)
please let me know if you need testing with other RPi version, I have a RPi3a and I can get back a RPi2 in the coming days
Many thanks for the extensive tests.
Would be helpful to check at least on a Pi3 since the changes to Pi4 were more radical than between e.g. Pi2 and Pi3.
I can confirm the trick works fine on RPi3a too
DSI touchscreen connected, original ( snd-bcm2835.enable_compat_alsa=0)
volumio@volumio-rpi3a:~$ aplay -l
Subdevices: 8/8
Subdevices: 1/1
DSI touchscreen connected, proposed fix ( snd_bcm2835.enable_headphones=1)
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 1/1
DSI touchscreen NOT connected, proposed fix ( snd_bcm2835.enable_headphones=1)
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 3/3
Subdevices: 1/1
Great! Thanks again for testing.
You’re welcome!
Thanks a lot!
I confirm this fix works. Raspberry Pi 3 A+ w Hifiberry AMP2 + DPI screen. Volume mixer works even after reboot.
