Again, no sound from Volumio Primo (I believe it is 3). Artwork shows, slider advances, no sound. What to do?
Configuration update
Player successfully restarted.
… no sound.
… no sound.
Can you try selecting the output device again?
If that does not work, please send a log and paste output here
It happens sometimes, usually after rebooting NAS (it goes off overnight), and then several volumio reboots might help it. Today, I can not even say how many times I rebooted it, even upgraded, nothing seemed to work. I found someone else’s old thread on this same topic with few suggestions. So I set the buffer to 12 and Mixer Type to “Software”. After reboot it started working again.
My suspicion is that there is something that does not start/initialize properly at the boot time. When everything is fine it will play a short sound after reboot, saying it’s ready. When not, it is completely silent.
Would you have any suggestions what to do when it happens again? I am sure it will.
I did change the output device, did not seem to help.
To understand we need the log ![]()
Will remember that, thank you.
Here it is, again, off and on, mostly off …
… and again,
http://logs.volumio.org/volumio/td1AOD7.html
… and each time I wonder, if it ever comes up again.
