No Sound from Volumio iOS App - Tidal Connect Works
Version 3.742
Hi there,
New to this. Tidal Connect is running perfectly and sounds great.
Unfortunately, nothing in the Volumio iOS app makes it out of my steamer and into my DAC. I can stream Tidal from Volumio app, but it doesn’t actually play on the steamer. Same thing with the CD player.
Feel like I’ve gone through all the menu options in the app.
Any suggestions?
Thanks!
It sounds like the streamer (Mercury V3) has a tweaked Volumio image that I wrote over when I selected auto-updates. Will report back on whether reverting to the streamer’s Volumio image fixes things.
