I have install New Volumio and only one plugin which work is spotify. RAdios and Youtube dont work.
Well, if you want help you might want to add some additional info other than “does not work”.
What does not work? Do you see that it’s playing in the main window? Anything queued in the queue?
Care to share some logs?
For YouTube did you go back into settings and switch the plug-in on?
no sound - application seems to be running
Again, you need to give some more information about what is working, and what is not working, if you want help to solve it.
Some first info that could be helpful for example: when you select a song from Youtube to play, what happens? Is it queued in the queue? Do you see it playing on the main window, is the time actually progressing?
